Newbie: How to develop?
Discussion in 'The Darkroom' started by Deco, Sep 29, 2004.
  1. Deco
    Deco TPF Noob!
    Sep 29, 2004
    30
    Hello I am new to photography.
    I would like to know a brief explanation on how a photo is developed in the darkroom. What chemicals it passes through and for how long.
    That is all I would like to know.
    Thank you. :)
  2. hobbes28
    hobbes28 Incredible Supporting Member
    Jul 10, 2004
    4,807
    41
    at work...
    Hello, and welcome to the forums. I moved your post to the darkroom forum because the regulars here can probably answer your question better.
  3. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Develop the film:
    Edit - pre wash - fill and let it soak for a little bit, dump and refill if it comes out purpley
    Developer - time will vary depending upon the film used and the developer used. Example, I generally use Ilford HP5+ 400 and it develops for 11 minutes in Rodinal at 1:50.
    Stop bath - 30 seconds
    Fixer - depends on the kind of fixer, rapid or non. I generally go 5-6 minutes just to be safe, even tho my rapid fix says it can between 2-4.
    Fill and dump with water 3 times
    Hypo-clear - 2 minutes
    Wash for 10 minutes - edit - I think I only wash for 5 minutes here. Now I can't remember since I'm not doing it...
    Swish in some PhotoFlo for a little bit. I don't time that part myself
    Making a print:
    Developer - After exposing in the enlarger, development times will vary. I usually do mine between 1.5 and 2 minutes.
    Stop Bath - 30 seconds
    Fixer - a couple minutes for RC paper, longer for FB. I don't usually time my fixing, I just leave it in for a while while I do other stuff.
    Wash - 10 minutes for RC paper, 20 or 30? for FB
    This is what I do anyway...
  4. gecko
    gecko TPF Noob!
    Sep 27, 2004
    98
    Southern Tier
    u use stop bath in your film developing?
  5. oriecat
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    yeah...
  6. gecko
    gecko TPF Noob!
    Sep 27, 2004
    98
    Southern Tier
    ookay
  7. oriecat
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    It's pretty standard practice...
  8. gecko
    gecko TPF Noob!
    Sep 27, 2004
    98
    Southern Tier
    i didnt say its wrong
    maybe its a westcoast thing ;-)
  9. rangefinder
    rangefinder TPF Noob!
    Jul 3, 2004
    148
    Texas
    The color that oriecat is referring to is the anti-halation backing on the film. Different manufactures may use a different color. Some are purple, red, blue and grey.
    I always prewet a couple of times to ensure the anti-halation backing was removed.
    I'm originally from the east coast. I always used stopbath.
    The anti-halation backing was put on film to absorb light bouncing off the pressure plate. As light strikes the film it passes through the film, hits the pressure plate and is reflected back onto the film. The anti-halation backing absorbs this preventing the film from being exposed a second time.
  10. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Here's how I do it...
    Film:
    Load 35mm BW film on to reels and in to developing tank.
    Make sure all solutions are at the same temp (68F is usually recommended).
    Pre-wet (water): 30 sec constant agitation, thump the dev tank on the floor to dislodge air bubbles.
    Developer: agitate for the first 15 sec, and then for 5 sec every 30 sec for the remaining time (varies with film, developer, etc...)
    Stop Bath: 30 sec constant agitation
    Fixer: agitate for at least 10 sec out of every 30 sec. Total fixing time is two times the clearing time. Clearing time is determined by dunking scrap film leader in fix and seeing how long it takes to completely clear (turn transparent).
    Wash (water): 30 sec constant agitation
    Hypo Clear or Wash Aid: 30 sec constant agitation
    Wash (water): 30 sec constant agitation, empty and refill with fresh water, 30 sec constant agitation, repeat for a total of 5 or 6 times or 10 min in film washer
    Photo-Flo: dunked in photo-flo, some minimal agitation
    squeegee with fingers and hang to dry
    Prints:
    expose print
    Developer: 1 min for RC and 2 min for FB, some agitation, I'll usually lift the print out of the developer once or twice
    Stop: 10 to 15 sec, constant agitation
    Fix: I follow the manufacturer's recommendations, 1 to 5 min depending on type of fixer and paper
    Holding Bath (water)
    Wash(water) RC: 10 min, squeegee on glass, lay on drying screen
    Wash(water) FB: 60 min or 10 min in hypo clear, and 30 min wash, squeegee on glass, lay on drying screen
    Stop Bath isn't absolutely necessary with film or prints, but besides halting the developing process, it extends the life of the fixer (which is typically one of the more expensive chems).
  11. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    It also keeps the whole roll of film from being fogged when light makes it through the felt trap on a 35mm cassette. Some IR films don't have the anti-halation coating, and that's why it's so important to handle them with care, as a little stray light can fog through the entire roll.
  12. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    I also will usually rinse several times. I was taught to always pre-wet to help prevent air bells, and to "prime" the emultion for the developer, but I run into lots of folks who consider it completely unnecessary. I figure it doesn't really take that much extra time, and there is all that anti-halation gunk (Forte film rinse water stinks!!), and even if the problems it solves are rare then it's worth it.
