Newbie wanting camera advice
Discussion in 'Photography Equipment & Products' started by pauluk, Aug 7, 2007.
  1. pauluk
    pauluk TPF Noob!
    Aug 7, 2007
    10
    Manchester UK
    im soooo confused :er:... ive booked myself in on a landscape photography course in the Peak District... very nice.. and now the tricky bit... picking a digital camera to buy...
    is the Pentax K10D good enough to create amazingly sharp images?
    I like the sound of it because its smaller and weather/dust proof, but wondering how much diference is there between the Pentax K10D and the bigger sized & res Canon/Nikons
    Are they worth the extra money and carrying about factor.
    Ive seen the thread on here 'Photo of the Month' which features some amazing images... Can they be acheived with the Pentax K10D.
    I must point out that I love night-time photography.
    Thanks for any replys :hail:
  2. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    K10D can... in the right hands... perform just as well as equivalently priced nikons and canons. IMO, its a good bang for the buck camera.
  3. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    The "other" guys also make small DSLR's. Weather and dust "proof" can be a misleading statement. You will still need to use caution at the appropriate time with any SLR, no matter the brand of format.
  4. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Yes the K10d is good enough to create "amazingly sharp" images, with the right lens and processing.
    Yes the images seen on the "Photo of The Month" could in theory be made with the K10d.
    Now both those statements equally apply to any dSLR, and indeed many cheaper compact digital cameras. The subjective quality or 'impact' of the photograph is determined by the photographer, not the equipment. And sharpness can be (and usually is) added in software. The thing to remember is that while amazing images can be achieved with the camera, the camera will not create amazing images; only you can do that.
    As for which camera is better or worth paying more for, only you can make that decision. We can give advice but bear in mind that we can't be completely objective, and what is best for each of us may not be best for you. Having issued that disclaimer, I'd say the following..
    Since you specifically mention an interest in night-time photography, that may mean long exposures, and therefore I would recommend going with a dSLR... a dSLR from any brand, but a dSLR as opposed to a fixed-lens compact model. Compacts may not have a "bulb" exposure option, and tend not to handle noise as well as dSLRs.
    The K10d is intended as an "advanced amateur" model. Other options here include the Nikon D80. But something less expensive may be perfectly adequate. An "entry-level" dSLR like the K100d, Nikon D50, Canon 350D etc will still have more potential than a compact model, and the money saved over a more expensive model can go towards lenses - the spec of the camera body means nothing if you don't have a good lens in front. When budgeting for your camera, I would look at the price of the camera body alone and then double that, since you may find yourself spending the same on lenses and/or flash and other accessories in a fairly short space of time.
    jstuedle is right to point out that "weather proofing" is misleading. The K10d is actually pretty well sealed against the elements in that you should be able to shoot in the rain but... and it's a big but... you will need to spend quite a bit (the same as the cost of the body) to buy lenses that have the same weather sealing. Having said that, it's easier to shield a lens from rain with your hand than it is to cover a whole camera, so having a weather-sealed body is still useful even without weather-sealed lenses. Either way, sealing is not the same as waterproofing. A dSLR is essentially a computer so you still need to take care of it.
    As for the difference between various cameras... well you can tell the differences between camera bodies, by looking at the specs for each. You can also check reviews and user opinions before buying. It may be worth reading up on some of the key concepts and terms, for example megapixels and resolution are not the same thing. Also consider that there are differences not only between individual cameras but between systems... Pentax, Canon, Nikon, Olympus etc all have their own system - the camera is only one part; lenses are vital, and the flash system and other accessories may also be important. So see what each system has to offer, as well as seeing what each camera has to offer. Finally, bear in mind that biggest or most don't necessarily mean best for you... what is most important is that the equipment enables you to create the images you want. So before you accept my word, anyone else's or that of some reviewer... get to a shop and take a look for yourself.
  5. photogincollege
    photogincollege TPF Noob!
    Aug 4, 2007
    706
    Grand Rapids, Michigan.
    Like everyone else says, we can give you advice on what direction in which to head but ultimatly it is your decision as to what camera you want. Go to your local camera store and feel them. A good trick that some people recommend is get a couple memory sticks, bring them to your local shop and take some shots with each camera on the stick and bring it home and see what you think of the pictures. Most good shops will let you. Just make sure you remember which pictures were takin on which camera.
  6. Mike_E
    Jan 26, 2007
    5,327
    266
    You can take Great photos with a pinhole camera. No, really, check out Steph's work with one... (I hope you don't mind Steph)
    http://www.thephotoforum.com/forum/showthread.php?t=81648
    One of the first things your instructor is going to tell you (if they are worth their salt) is that it's the Photographer that makes the photo.
    mike
  7. pauluk
    pauluk TPF Noob!
    Aug 7, 2007
    10
    Manchester UK
    thanks for all the advice, think i'll buy the pentax and get a decent lens :thumbup:
  8. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    :thumbup: I'm sure you won't be disappointed.
    Do ask if you want any advice on lenses, there's a few Pentax users here who will be happy to help or at least point you in the right direction.
