Newbiee Needs Help w Kodak Z812is Trouble
Discussion in 'Digital Discussion & Q&A' started by riddermark, Aug 14, 2009.
  1. riddermark
    riddermark TPF Noob!
    Aug 14, 2009
    i probably need an idiot's guide to photography.
    that's another thing. this is what i want to know ...
    been using kodak z812is for a year on its orig setting.
    cousin tried to manipulate settings a few days ago.
    and now the flash opens up but wont work. have
    set it back to factory setting (i guess back to orig)
    still no flash.:(
    what could be the problem? can the flash bulb be replaced?
    need inputs. thanks!
  2. KmH
    Apr 9, 2009
    40,733
    5,587
    Iowa
    Do you know how to discharge high voltage capacitors?
    It's not likely to be a bad bulb but a camera setting you missed. Do you still have the users manual? That's always a good resource.
  3. riddermark
    Aug 14, 2009
    no i dont know how to discharge high voltage capacitors.
    m really an idiot on this. hope i could still find the manual.
    help on how to do it (discharging) ?
    would appreciate it v much!
  4. Dagwood56
    Dagwood56 No longer a newbie, moving up!
    Jul 19, 2007
    2,944
    448
    I think KmH was being a bit facetiuos about the discharging. ;) Your best bet is to locate the owner manual, if you don't have it, search online. Google your camera make and model plus owners manual. Most companies provide downlodable versions of product manuals. Once you have a maual to look at, find out how to put the camera back to its factory defaults and you should be fine. I think as KmH stated , you probably missed one of the settings.;)
  5. riddermark
    Aug 14, 2009
    thanks for the replies!
    yes i tried searching for the manual in the net but nothing is said further about resetting flash or flash malfunction. have set it to its factory defaults, still problem is unsolved. it will probably need me to send it to service center which we know would cost too much!:(
  6. Dagwood56
    Jul 19, 2007
    2,944
    448
    Try taking it into your nearest camera shop. Tell them you lost the owners manual. Tell them exactly what happened and ask if they might know what the problem is. The worst that can happen is they tell you they can't help you. Second worst, will be they tell you to send it for repair at which time you simply say you'll have to wait till you have the funds. No harm in trying and you might get lucky. ;) Good luck.
  7. gjtoth
    gjtoth TPF Noob!
    Feb 5, 2008
    62
    Louisville, Kentucky, USA
    You could try removing the battery for 24 hours and see if that does the trick. I had a Z712 that had some weird stuff going on. I, too, tried resetting to factory defaults and nada. I removed the battery as suggested by a forum user and, voila... Of course, I had to reset the time & date but the camera never malfunctioned again.
