Night Club Photography
Discussion in 'Photography Beginners' Forum' started by nima, Apr 23, 2007.
  1. nima
    nima TPF Noob!
    Feb 1, 2007
    44
    Indiana
    Hey,
    I just bought my Canon 20D and 24-70 L lens. I also have a 50mm f1.8...
    I need to do night club photography every weekend. I was wondering what tips you guys can give ....
    I was thinking use ISO 400 and use larger aperture
    Thanks
  2. fightheheathens
    fightheheathens TPF Noob!
    Aug 1, 2005
    1,011
    Berkeley
    fast lenses are your friend.
    50mm 1.8 is a good think to have
    zooms with max/constant aperature of 2.8 are also good.
    a flash that you can angle is also good.
  3. nima
    nima TPF Noob!
    Feb 1, 2007
    44
    Indiana
    So you think I should use the 50mm and not the 24-70?
  4. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    If your planning on doing this professionally you'll need a lot more than a fast lens, high iso and a wide aperture.
  5. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    Im not sure what night club photography is but I'm guessing it happens at night so here's my suggestions. Def a high iso 800 is prob good. Def use the 50mm 1.8.
    Another trick you might want to try is to use your flash but bounce it instead of aiming towards the subject. If your indoors bounce off a ceiling if your outdoors try pointing your flash straight up and attach a white index card to the back of flash with a rubber band. Experiment with the flash to get the best exposure.
    But flash should always be a last resort, atleast it is to me.
  6. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Nightclub photography NEPats is basically that - Photos of people and/or events in a nightclub (disco or whatever you call it where you are)
    In a dark club even f2.8 will be too slow. I'd look at buying a fast wide prime - possibly a Sigma 30mm f1.4 or something like that. The 50 will be ok but it can be a little long using it on a 20D.
    Using flash (if you have one) is a decent option if needs must. You may need some practice to get it looking right. With the 50 f1.8 you can use it with fairly low ambient light and fairly slow shutter speeds to get people sharp but with the feeling of movement.
    Whatever you do..... good luck.
  7. JDP
    JDP TPF Noob!
    Aug 16, 2006
    285
    Minneapolis, MN
    Nah, 2.8 should be fine - I shoot low light events constantly with a 17-55mm and never had a problem, from sound stages to night clubs, its a good all around night lens!
  8. nima
    nima TPF Noob!
    Feb 1, 2007
    44
    Indiana
    Thanks a lot guys....
    I will use the 50mm this weekend and higher ISO (between 400-800) and will let you know how it goes..
  9. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Suppose it depends on the nightclub. With some decent lighting yes but in the club I used to go to..... even the 50f1.8 would struggle :)
    THe 17-55 has IS which helps a bit.
  10. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Never shot in a nightclub but I've shoot in tight crowded areas at night... including subways and such. It is a fun challenge.
    Use the fastest primes you can afford. I carried a 24, 35, and 50. Often found 50mm a bit too long even on full frame. 35mm was pretty ideal. You can typically hand hold shorter focal lengths anyways. Keep track of areas that have a bit more light as you chances for a good shot increase in those areas. Keep track of places that you can use to steady yourself (building support posts, outer walls, bar handrails, etc) . I use a loose messenger bag with Domke padded dividers; 1 compartment for each lens. Leave the lens caps and rear caps off. I found myself switching between lenses faster and dropping a cap in a crowded area usually means it is lost forever.
    Flash has never really a good option for me but I have used a flash pack on occasion. When you enter an area, take note of the ceiling when you enter. How high is it? What color? I once used bounce and didn't realize that the ceiling was painted a deep purple.... DOH!. If you do use a flash, try to get the background exposed even a little so it looks like the subjects are in a club rather than a completely black background.
    Good luck! and have fun.
  11. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    If you are in a club, you will probably notice that MOST of the atmosphere is created by the lighting. I assume that you are taking people. so the 50mm will be close enough magnification wise. and at f1.8 with a 400 to 800 ISO should do the trick. Flash will bleach out all the coloured lighting that the people concerned have spent a long time creating, and make the subjects look as though they are posing in the office...
    really to give a good answer we will need to know more about what you are photographing and when and how etc etc.
  12. nima
    nima TPF Noob!
    Feb 1, 2007
    44
    Indiana
    I know that I should post pictures for review in another topic but i thought it would be more appropriate to post it here....
    Here are two pictures I took last week using the 24-70 and flash (camera body's flash)
    [​IMG]
    [​IMG]
