I went out the other night and found out that it is really hard to focus on something you cant see very well so if anyone had any tips on how to focus at night i would appreciate it. thanks
I assume you are shooting digital, so the lens should automatically focus, but as you say, if it's very dark the camera does have a problem. All you can do is set your camera on manual and focus through the viewfinder. The lens though should have distance markings on it. Good luck.
In Low-Light settings, I usually switch to Manual Focus as well. Your choice is really to spend the cash to buy a faster lens (and f/2.8 zooms don't come cheap), which even then doesn't guarantee results in low light, or to learn to manually focus.
What camera are we talking about here? Is it that auto-focus won't work...or that you just can't see well enough?
Autofocus needs something that it can see...something with contrast. (a blank wall won't help much).
A lot of cameras have AF assist. There are several different types. Some shine a small light onto the subject. Some fire the flash several times. Some use an IR beam to get the distance. Sometimes a dedicated accessory flash will assist the camera to focus.
Back in the day, most lenses had distance scales on them. You could estimate the focus by knowing or estimating the distance to the subject and set the lens with the scale. Most newer lenses do not have this feature anymore.
im using a 350d with a 17- 40mm l lens. I have been using manual and basically doing what you guys said, kinda estimate the length and set the lens that way. I didnt know if there was some special technique that was easier or not. thanks everyone for the quick responses
I dont know if this will solve your problem, but it works for me...
Sometimes If the subject I want to focus on isnt too far away I can use a flashlight and light it well enough to see in the viewfinder to manual focus it, or it may trigger enough light for the auto focus...
with the kit lens, you can swivel the tripod head around and find something same distance bright enough to lock focus onto while you are zoomed into it
then unzoom and swivel and recompose.
If the subject is close enough, the pop-up flash will act as an AF assist light when you pop it up. If you're shooting something like a landscape or building, however, you're kinda outta luck (unless, of course, the object is past infinity; then you just set the lens to its farthest focus)
i took some photos of my boyfriends car and his friends car the other night and at first i manually focused and the pictures were soo blurry but they would of looked great so i just used auto focus.
Or manual focus and do a couple shot. Maybe set the lens to infinity, turn the camera to burst mode. As you hold down the shutter button slowly turn the lens to the closer focus.
I like darin's idea... and also the suggestion of a flashlight, though that can only work in certain situations. Other thing to try is focus on an bright object that is an equal distance (approx) away from the camera to whatever your shooting, then recompose for the shot you actually want to take.
