night shots
Discussion in 'Beyond the Basics' started by hollisterguyo7, May 14, 2008.
  1. hollisterguyo7
    hollisterguyo7 TPF Noob!
    Mar 30, 2008
    84
    my friend wants me to photography an event/party its inside n its pretty dark it sometimes has a strobe light going n stuff... i have a canon rebel xti what would be the best settings to start off with n go from there... i have the regular flash nothing better lol anything would help he is also gonna have a band inside
  2. McQueen278
    McQueen278 TPF Noob!
    Mar 24, 2008
    388
    Ann Arbor, MI.
    go buy a 50mm 1.8 if you don't already have one. Leave your 18-55 at home. Use the pop up and pray. You might also look into one of those funky softboxes that strap onto the pop up. Shoot in shutter priority at 1/250 which is the fastest speed your camera can sync with the flash. Also, try shooting with a 2nd curtain flash. This will help with moving subjects and maybe dial down the flash intensity a step or so.
  3. hollisterguyo7
    Mar 30, 2008
    84
    alright i wont be using a tripod wont have a chance so what should i try seeings how i will be moving around inside...
  4. McQueen278
    Mar 24, 2008
    388
    Ann Arbor, MI.
    everything I suggested assumes you will not be using a tripod. At 1/250 you won't need it.
  5. lockwood81
    lockwood81 TPF Noob!
    Jun 10, 2007
    887
    Daytona Beach
    Everything McQueen said and dial up your ISO.
  6. hollisterguyo7
    Mar 30, 2008
    84
    thanks i just went into a closet n tried it n it came out pretty good ive just gotta pray haha everyone will be dancing n movingg im hopeing i can get them to pose a bit
  7. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    try a 50mm f/1.8, and ISO 1600, Yes it can be noisy, but I have had very good results, and on smaller prints the noise is not even an issue. If you still need flash I would dial it down to a minimum, and go from there.
  8. SBlanca
    SBlanca TPF Noob!
    Dec 28, 2007
    405
    Gibraltar
    try Neat Image in post processing for the noise and stuff...
    and yeh big aperture and high ISO could be your best friends on this one...also remember that the on camera flash isn't all that great unless you're up close to people..
  9. hollisterguyo7
    Mar 30, 2008
    84
    i have a 18-200 n my starter lense would i be better off using my 18-200 or my starter lense
  10. McQueen278
    Mar 24, 2008
    388
    Ann Arbor, MI.
    Is your starter lens the 18-55mm f/3.5-5.6 USM or the 18-55mm f/3.5-5.6 IS USM. If you by chance have the IS version, I would take that one.
    Is you 18-200 the Sigma? If so then I would take the kit lens regardless simply because the kit lens is faster at the long end.
  11. hollisterguyo7
    Mar 30, 2008
    84
    it isnt the is... n no its the tamaron 200mm
  12. McQueen278
    Mar 24, 2008
    388
    Ann Arbor, MI.
    If I were you'd still take the 18-55, but it's really about what you are most comfortable with. Just keep in mind that past 50mm that built in flash will likely be useless. Actually, the 18-200 may be too long of a lens period. You might have a dark spot at the bottom of every image where the lens obstructs the flash.
