Night skyline
Nice; I think because of how bright the capitol building is however, an HDR would work better here. Expose say, 1.5 seconds for the main scene to bring more detail out, and a just a bit less than you used here to recover some of the detail in the capitol building.
Lower the ISO to 100 (better quality), apature @ 11ish (so it's all in focus), 15-25 second exposure, manually focus it and toss it on a tripod. Just my .02 but nice shot!
Hey hey! That looks familiar! A fellow Madisonian! It looks to me like either the image is soft from missed focus or too much cropping/too high ISO. What lens were you using?
A couple other thoughts that work well for me. As already mentioned, lower your ISO and increase your exposure time. Were you using a tripod? Try to find the sharpest aperture for that lens, use it, and adjust the shutter speed accordingly to get your exposure right. It's a nice start, thought. I've actually shot the same shoreline from the other side of Lake Monona. I used two exposures, layer masking the Capitol Dome, but even then, I still ended up with a slightly overexposed dome.
Capitol Shoreline-7 by crimbfighter, on Flickr
I agree with the tripod and longer exposure. Nice shot though.
I was using my tamron 70-300 f4-5.6 at 300mm, it is really my only telephoto that works on my new fx body (just upgraded to d750 from d200). I was using a tripod, I will try lowering the iso and uping the exposure time. I am still pretty new to this so will need to look into the multiple exposures and layer masking.
For some reason when I was trying longer exposures the light was trailing somewhat. I need to figure out whats going on with that.
Lots of good input here for me to try this week, thanks!
Here are a couple other suggestions for you to try for long exposures on a tripod.
-Find the sharpest aperture/focal length combo and use it. Your lens might be sharper at even 270mm rather than 300mm, and therefore might produce a better image, even if cropped more. Especially with super zooms like yours, they tend to get soft right around the 300mm mark. Sometimes backing off a few mm can make a big difference.
-Does your lens have image stabilization? If so, make sure it's off when on a tripod. The IS systems can actually INTRODUCE movement because the little mechanisms inside are moving about trying to find instability even when it doesn't exist.
-Were you using a remote shutter release? If not, try one. If you don't have one, try using the timer function and set it to at least 5 seconds so the camera can settle from the pressure of pushing the shutter release before it takes the photo.
-Lastly, try using the mirror up function, which requires two presses of the shutter release. One to raise the mirror, and one to open the shutter.
Hope that helps!
Hope that helps!
Thanks, I will work on figuring out the sharpest focal length. The lens does have image stabilization which I was using, maybe that was what was causing the issue I couldn't explain, thats a really good observation. I am using a remote so I wasn't actually in contact with the camera at all during the exposures. I kept thinking it must have been something similar to the 600 rule with stars that I was just too inexperienced to figure out. I couldn't find anything when I researched until you just clued me in on the VC, I'll do some looking into that.
