nightime photoshoot
Discussion in 'Photography Beginners' Forum' started by swmocity, Jul 31, 2008.
  1. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    dont know if i should use a flash or not...if i use no flash then i would need a long shutter speed..yes i know...or should it be a faster shutter speed with the flash?
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    You'll have to provide a little more information. What you're shooting, where, type of equipement, etc.
  3. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    a friend of mine is the subject..in a park and also a shopping strip..im just going to use my kit 18-55 and my rebel...if i can find a good enough in store deal i will buy the canon 430ex flash tomorrow(hopefully)..if not ill stick with the pop up flash
  4. Tolyk
    Tolyk TPF Noob!
    Aug 10, 2006
    524
    Calgary, Alberta
    Good luck finding the 430 ex, the ex II was released and the ex is discontinued.
    As to the shoot, if you're doing action shots at all, you'll need the flash, if you are doing still portraits, the ambient light can look really interesting. Depends what you're doing, as the other poster said
  5. iflynething
    iflynething TPF Noob!
    Oct 26, 2006
    1,346
    South Carolina USA
    With the kit lens and the amount of light it lets in, I sure hope your friend can stand still for a couple seconds and I sure hope you're not goint for a sharp shot
    EDIT: Just noticed you have a 50mm 1.8. USE THAT!!
    ~Michael~
  6. Tolyk
    Tolyk TPF Noob!
    Aug 10, 2006
    524
    Calgary, Alberta
    And yeah, what they said :D
  7. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    i guess the net is the only way i can get it...wats the diff. between the two?
  8. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    because of the low aperture?...then i can make my shutter speed faster?
  9. iflynething
    Oct 26, 2006
    1,346
    South Carolina USA
    Oh buddy!! Pop that baby on, set it to Av (Aperature Priority on your Canon) and stop it down to 1.8. That is a fast lens (although there are faster). That second number is like the iris of your eye. It opens and closes to change the amount of light into the eye [camera]. Its a little bit of an inverse though because the smaller the number, the larger that iris [aperature] becomes allowing for more light into the sensor and an increased shutter speed.
    I shoot Nikon so I unfortunately can't answer the difference on the 430ex and the 430II. Sorry
    I hope this helps you
    ~Michael~
  10. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    thanks alot...one more question...1.8 has a shallow DOF but im trying to shoot full body pics and keep the whole body sharp...can this be done at 1.8
  11. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
  12. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    I SO disagree with a lot of the advice in this thread.
    If you are using a flash, then 1st, shutter speed doesn't really matter regarding your subject being lit. At 1/60th versus 1/500th the subject will be lit the same and the flash will freeze any action.
    The shutter speed is what you will use to balance the ambient. Set your aperture to whatever you want (I'd do closer to F8 since you might want some of the background lights in focus. Then (with the flash off, Meter the background to the look you want), then kick on the flash (use TTL if you choose) and snap. Now your subject will be lit by the flash (may want to adjust the flash exposure comp one way or another) and the shutter speed will be exposed for the background.
    Edit: If you didn't catch this from my post.....you should be shooting full manual mode when using a flash. If you shoot aperture priority then you have no control over the ambient light's exposure and the camera decides for you. Shooting manual lets you decide how much background light will be in the scene. Faster shutter speed, less ambient light....slower for more.
