Nikkor 18-200MM Telephoto
Discussion in 'Photography Equipment & Products' started by Klptix17, Apr 21, 2008.
  1. Klptix17
    Klptix17 TPF Noob!
    Apr 16, 2008
    11
    Central Jersey
    Hey guys does anyone have this lense for their Nikon and have any thoughts on it?
    I'm trying to do my research on what telephoto lense I should buy.
  2. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    I suggest doing a search on the forum... there have been lots of topics on this particular lens.
  3. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,340
    16
    Caribbean
    There are literally thousands of reviews around the internet. Here's a synopsis: Enormous focal length and Vibration reduction are highly convienient, and this particular lens is relatively good considering it's large focal range. However, it won't ever be quite as sharp as a prime lens and many zoom lenses. It also has a relatively slow max aperature, and while it's handholdable in pretty low light, it won't be very good at capturing subjects in motion. Distortion will also be very bad at the extremes of the focal range, you will have barrel distortion on the wide end, like this: ( ), and pincushion at the tele end, like this: ) (. Hope that helps.
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    There are literally thousands of reviews on this very forum!
  5. EricBrian
    EricBrian TPF Noob!
    Feb 17, 2008
    503
    I have that lens and I agree with Antithesis.
  6. Rhubarb
    Rhubarb TPF Noob!
    Dec 16, 2004
    286
    Roaming the globe
  7. Ben-71
    Ben-71 TPF Noob!
    Apr 28, 2008
    203
    Israel
    I have the 18-200 and some others. It was the first for the D300, and is the most used.
    It is not at the level of the Pro 70-200 for instance, but it is the one that's constantly on the camera. The 18-200 is good enough, light enough, and has the wide range to capture the moment that would have slipped away if I stopped to change lenses.
  8. jlykins
    jlykins TPF Noob!
    Dec 1, 2007
    1,235
    Cincinnati
    I have it on my D70 most all of the time. It's a great walk around lens (meaning just this lens and the camera is all you'll need) for just about every situation I am in.
  9. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    If you don't care about quality and need to go from 18mm to 200mm in a split second, then get it. It's convenient, and if you're in an area with adverse conditions, you won't have to change lenses.
    However, if you go for a lens with a smaller range, you'll get higher quality images because there will be fewer compromises. For the amount of money the 18-200 is, I think the 16-85 is better, and if you're not afraid to buy used, you can get a 17-55 f/2.8 for a smidgen more. I used to own the 17-55 f/2.8 and it will knock the socks off the 18-200. Sharpness is about on par with the 16-85, but 17mm at f/2.8 is just as sharp as f/8, it's insane.
  10. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    JIP and Socrates must be offline.. hehehe lol
  11. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    You beat me to the punch! Ha :lmao:
  12. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I think I will stay out of this one.
