Nikkor 70-300mm for Nikon D60
Discussion in 'Photography Equipment & Products' started by denshot, Aug 15, 2008.
  1. denshot
    denshot TPF Noob!
    Aug 15, 2008
    4
    First time poster and novice Nikon D60 user.
    Am I correct in assuming this lens:
    AF-S VR Zoom-Nikkor 70-300mm f/4.5-5.6G IF-ED (4.3x)
    on this camera:
    Nikon D60
    The VR "Vibration Reduction" feature will NOT work?
    Any and all comments and help appreciated.
  2. Lyncca
    Lyncca TPF Noob!
    Jan 7, 2008
    1,881
    5
    Fort Worth, TX
    I may be wrong but I thought since the VR was a part of the lens that it wouldn't matter what camera it was on? I have the D70S and that lens' VR works.
  3. Slaphead
    Slaphead TPF Noob!
    Apr 28, 2008
    399
    Z├╝rich, Switzerland
    The VR is in the lens, not the camera. I have the same lens and use it on a D40x (the model before the D60, but practically the same camera) and the VR works fine. In fact with that lens everything including autofocus should work on the D60, no problems. HTH
  4. denshot
    denshot TPF Noob!
    Aug 15, 2008
    4
    Yes, the VR is in the lens but there also must be the correct electrical connectors between the camera and the lens.
    The reason I ask about this is that all the specifications I see for the Nikkor 70-300mm f/4.5-5.6G IF-ED say that it works with the D40 and the D70 and never mentions the D60 which leads me to believe the VR is not compatible with the D60. I hope I am wrong about this assumtion as I would like to buy the lens but I could go with the older and cheaper 70-300 lens without VR if VR is not going to operate correctly.
  5. turnbeaugh5
    turnbeaugh5 TPF Noob!
    May 26, 2008
    42
    The VR will definitely work on the D60. Just remember if you go with an older version though, it will not autofocus on the D60. It must have the DX designation.
  6. denshot
    denshot TPF Noob!
    Aug 15, 2008
    4
    Okay, Thank you. I understand about the auctofocus. Just to clarify and confirm, will the VR aspect of this lens operate correctly on my D60?
  7. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    Probably because the lens is older than the D60, and the description hasn't been updated.
  8. denshot
    denshot TPF Noob!
    Aug 15, 2008
    4
    That makes good sense. Thank you!
    I appreciate the help from all of you.
photos for nikon d60 with 70 300 lens
