Nikon 50mm lens
Discussion in 'Photography Equipment & Products' started by mltran, Jan 30, 2009.
  1. mltran
    mltran TPF Noob!
    Jan 19, 2009
    28
    Brooksville
    I am thinking about getting a 50mm lens, what are the differenced between the two lenses:
    Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens
    and
    Nikon AF-S Nikkor 50mm f/1.4G Autofocus Lens
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I believe the AF-S is the new one that came out not long ago. For those who have the Nikon DSLR camera that do not have the focus motor drive pin. i.e. D40, D40x and D60.
  3. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    The D50 has a built-in AF motor, so you can save a few bucks and get the AF-D model.
  4. mltran
    mltran TPF Noob!
    Jan 19, 2009
    28
    Brooksville
    Thanks for the help!
  5. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    Agreed, the 50mm lens is so light that there isn't much of an advantage to afs.
  6. shivaswrath
    shivaswrath TPF Noob!
    Sep 18, 2007
    302
    Norwalk, CT
    with a D50, you're better off with the AF version; I own the AF-S version, and it is amazingly sharp, and the AF is lightning fast - I just can't say what sort of difference you would see with a D50 that already has the AF motor built in.
    I would suggest trying them both side by side, they say the AF-S version is a little sharper and faster, but gives up a little in the contrast side of things (from what I've read. . . .)
  7. LWW
    LWW No longer a newbie, moving up!
    Aug 3, 2005
    1,224
    7
    Dayton,Ohio
    FWIW take a peek at a 1.8 also.
    LWW
  8. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    I believe the 50mm f/1.4D has the aperture ring for use on older cameras, and the G doesn't.
  9. Captain IK
    Captain IK TPF Noob!
    Dec 5, 2008
    630
    Windsor, ON. Canada
    I use the 1.8 and it is a fantastic lens...also less than half the price of the 1.4
  10. Double H
    Double H TPF Noob!
    Nov 12, 2007
    550
    24
    Around the corner from the Turkey Hill, PA
    Agreed. I recently got the 1.8 and it is a great lens, especially for portraits. Tack sharp, I say, tack sharp.
  11. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Unless you have a D40/X/60 then there is an advantage. To the poster get the non-AF-S. I could almost see the price justification if they made it into a DX version as well as AF-S. But that isnt the case.
