Nikon 70-200mm f/2.8 Lens
Discussion in 'Photography Equipment & Products' started by Josh220, Jun 6, 2009.
  1. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    "Vibration Reduction works only with N65, 75, N80, F100, F5, D70, D100 & D1 series (or newer) cameras."
    That is stated on B&H for the 70-200mm lens, does that mean VR won't work with my D60? What makes VR model specific?
  2. Defy
    Defy TPF Noob!
    Jan 24, 2009
    271
    Ohio
    My wife has a D60 and my 70-200 2.8 works fine with it, VR too.
    Also before you buy the 24-70 2.8 and the 105 Macro look into the 35-70mm 2.8 with the Macro option. http://www.kenrockwell.com/nikon/3570.htm
    I just picked that one up and it's is a way cheaper alternative to the 24-70mm.
  3. Josh220
    May 23, 2009
    1,730
    83
    California
    I'll look into that, thanks!
    I wonder why they state it only works on D70 and newer models...
  4. RONDAL
    RONDAL TPF Noob!
    Sep 8, 2008
    353
    The Great White North
    D series........you have a D60 ........
  5. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,216
    240
    Los Angeles
    Older cameras don't have the computerized thingies inside them to deal with the electronics of the vibration doohickies in the lens.
  6. Josh220
    May 23, 2009
    1,730
    83
    California
    It doesn't say D series....... It says D70 and newer........ So I decided I would ask....... That way I know if I need to get the D300 first.......
    That's what I figured, but since it specifically said D70 I just wanted to double check. Better safe than sorry when spending $1800 on a lens.
  7. farmerj
    farmerj TPF Noob!
    Apr 26, 2009
    588
    well, which one came out first...
    The D60 or the D70?
    This will open a pdf file link with a timeline from 2005 to 2009.
    The D70s came out in 2005. The D60 came out in 2008.
    So the D60 is Newer than the D70.
    numerical models aren't always chronological models.
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Exactly. They really meant newer, and not higher end. The D70 D100 and D1 were all the first proper commercial cameras in their lines, though I'd say the D40 is missing from the list. Everything since then works perfectly. In otherwords pretty much every Nikon Digital SLR since 1999 *or ever Nikon DSLR bar the prototype / testing the digital waters cameras, supports VR.
