Nikon D300 6 FPS...
Discussion in 'Photography Beginners' Forum' started by Kenny32, Aug 7, 2009.
  1. Kenny32
    Kenny32 TPF Noob!
    Jan 24, 2008
    168
    So, I've used a D300 before...but the one I just bought arrived today and it seems like it doesn't want to go to 6 FPS...
    I have the shutter at 1/8000 (I just want to test it)...I have an EL-EL3E battery in the D300 and another in the MB-D10 (It's set to use the one in the D300 first)...the CL Mode Shooting speed setting is at 6 FPS, and the release mode in the camera settings is at CH and the dial on top of the camera is at CH as well...
    I count "one-thousand one" and it only takes 3 photos...
    What am I missing?
  2. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    I think you need to use AA's or the special battery ($$$) EN-EL4a I believe it is.
  3. Kenny32
    Kenny32 TPF Noob!
    Jan 24, 2008
    168
    That's for 8 FPS with the grip...I know I can only get six with the current setup now.
  4. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    For starters, the one thousand one thing isn't the most accurate, sorry. Also, most FPS ratings are marketing hype, and frequently a little slower than they claim. Also, FPS can be dependent on what focus mode your are in. Also, I think the D300 has some burst mode option, when it will prioritize actually being in focus over maximum frame rate. You can turn it off if you want it to shoot full speed, but all the shots might not be in focus. Dig through your menus and see if it has that option.
  5. KmH
    Apr 9, 2009
    40,526
    5,539
    Iowa
    If you have High ISO noise reduction turned on it will slow things down considerably.
    It sounds like you've read the manual but I know I refer to mine all the time when I'm unsure.
  6. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Turn it to MF, Use a stop watch, Manual mode, no noise reduction et al
  7. boogschd
    boogschd TPF Noob!
    Mar 19, 2009
    606
    ph
    active d-lighting - turn it off
  8. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    It needs to shoot in 12 bit, not 14 bit. The D300 and d3x slow down, where the D700 and D3 don't with 14 bit.
    Active D lighting off, 12 bit, CH with the enel3's will give you 6fps.
  9. Kenny32
    Kenny32 TPF Noob!
    Jan 24, 2008
    168
    Yep, the 12 bit did it...Thanks everyone!
