Nikon D300S Users - Please read....
Discussion in 'Photography Equipment & Products' started by bburzycki, Jan 17, 2010.
  1. bburzycki
    bburzycki TPF Noob!
    Jan 5, 2010
    46
    San Francisco Bay Area
    So I recentalyl upgraded to the D300s from a D100 and I have a strange anomoly happening with CF cards and the ammount of photos the camera claims I can shoot vs. what I can shoot.
    Camera: 49 avaiilable
    Real world:90 plus shots taken
    Thats a major discrepency.
    Are others having this issue?
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    are you shooting compressed NEF or jpeg? if so, the initial number is just an estimate, not actual. when you shoot 14 bit uncompressed nef or jpeg size priority, the number is generally more accurate.
  3. bburzycki
    bburzycki TPF Noob!
    Jan 5, 2010
    46
    I am getting an idea that all the numbers no matter what I set it too are just very bad estimates of frames able to be shot..
    In this case I am set to NEF - Non-Compressed which should give me a huge file - yet the number does not change when I go to compressed or lossless compression.
    Looks like lossless compression might be good but that might only be able to be unpacked properly Nikon only software editing suites..
    Man way to many options... just give me a RAW and treat it the same across mutiple editing programs.
  4. KmH
    Apr 9, 2009
    40,051
    5,451
    Iowa
    Each image you make has a different amount of information and thus a different total file size.
    Since Nikon doesn't know what you will be making images of, they can only estimate how many images each GB of card storage space can hold.
    Perhaps, you would been happier with the much simpler D90.
  5. bburzycki
    bburzycki TPF Noob!
    Jan 5, 2010
    46
    Yeh ok - I have been shooting for years with mutiple Nikon bodies and needing a simplier camera is not the case..
    There is a stunning difference between 49 estimated frames and then being able to shoot 90 frames - as long at the setting is not changed the estimage should be accurate...or at least more accurate.. my D100 was right on the money and that camera was made 4 years ago...
    I can understand the # changes based on content and level of detail picked but 40 plus frames.. that seems lazy to me.. so in a professional marketplace I am shoooting and look down to see a number that means nothing to me and I just shoot till the cards stops recording... thats not a great solution that is like a gun with random qty of ammunition - or an idiot light on a car.
  6. Wolverinepwnes
    Wolverinepwnes TPF Noob!
    Oct 28, 2009
    289
    go to your menu setting and select the option where the file size is kept constant regardless of image and see if that makes the issue go away if it doesn't i would call up nikon I have never had that problem with my D300s.
  7. KmH
    Apr 9, 2009
    40,051
    5,451
    Iowa
    :scratch:
  8. bburzycki
    bburzycki TPF Noob!
    Jan 5, 2010
    46
    What card types and sizes are you running?
    What ammounts are you seeing when in the typical modes you are shooting?
  9. bburzycki
    bburzycki TPF Noob!
    Jan 5, 2010
    46
    This appears you do not understand.... can I help to solve your :scratch:
  10. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    It is not so much a matter of Quality (Raw or Jpg) what the camera is estimating is the data. Take a Picture of a solid white backdrop, then a sold black and then a mixed color. You will find the file size is different for every one if using compressed RAW or just RAW.
    I would rather have my camera underestimate my space than over estimate it.
  11. Mike_E
    Jan 26, 2007
    5,327
    266
    I know this is a stupid question but did you format your card/ and does it happen with every card?
  12. bburzycki
    bburzycki TPF Noob!
    Jan 5, 2010
    46
    Fully formated - happens on all my 2GB cards - they are not the newest things in the world but never had similiar issues in the past...
    I will have time this wekeend to sit down and really look into the issue...
    But I am pretty sure I covered every obvious base at this point..
