Nikon D3200 Photos Blurry
Discussion in 'Nikon Cameras' started by Seiorai, Sep 1, 2013.
  1. Seiorai
    Seiorai TPF Noob!
    Sep 1, 2013
    5
    Hi everyone!
    I am a total newbie to digital photography (just bought my first DSLR, a Nikon D3200 a few days ago) and I am facing a blur issue or two that most likely are caused by me not knowing how to use the camera (I hope). I tried looking on Google for a solution but could find none that would actively help.
    So first thing's first: the camera came with the standard 18-55 lens. No matter how far away the object that I want to photograph is, turning my lens from 18 to 55 doesn't help because it simply produces a blurry image, instead of bringing it closer (as I think it should?). And I'm not talking 2-meter away object, I'm talking 500+m-away. Both foreground and background, so can't say it focused on something close and blurred the background...Tried both Autofocus and Manual, but maybe I'm still dong something wrong?
    Second in line is the end-product blur. Here is a photo taken the other day and it looks horrible. I was standing still, holding my breath and holding the camera as the User Manual instructs, to provide max stability. Here is the EXIF data for it which is mostly alien-ish to me since like I said I am new to all this. The lens's VR was on too. Autofocus was on (the A/M slider on the lens). Photo size/quality was Normal/Fine.
    Basically out of 700+ photos, about 30-40 are decently usable and you can make out something, the rest are a blurry mess where you have to zoom out/resize to 10% to see a decently clear picture. I have to specify that these were all taken using the same method: camera hold as User Manual instructs, firm on my feet and holding my breath. Even when trying to catch a writing (name) on a jacket 6 ft. away from me, with minimum zoom (18), the name is blurry/unreadable...
    I'd really appreciate any help with this, and if I can provide any more info please say.
    Thanks in advance!
    Edit: Here is one of the sharpest pictures for comparison
  2. Juga
    Juga No longer a newbie, moving up!
    Jan 18, 2013
    1,245
    375
    Charleston, SC
    It is VERY far out of focus. Did you check your diopter?
  3. elementgs
    elementgs No longer a newbie, moving up!
    Sep 1, 2013
    135
    26
    California!
    "Focus Mode: Manual" (From your exif)
    Check the lens again. Make sure nothing is locking the focus ring in place.
    You're firing in manual.
  4. Seiorai
    Seiorai TPF Noob!
    Sep 1, 2013
    5
    I turned it from left to right but it looked more in focus at the normal setting, right in the middle of +&-. Once in the middle, it wouldn't turn from right to left at all so I just left it in the middle since it was clear anyway?
    I set it to manual from the camera, but it was set to A from the slider on the lens? Even in manual, I tried to rotate the lens to get a clear focus and the only clear focus was at 18-20 tops. And though it looked clear on the viewfinder, it's..really blurry in the final photo?
  5. ToddnTN
    ToddnTN TPF Noob!
    Jun 24, 2013
    75
    7
    Nashville, TN
    You need to have both the body and the lens set to auto-focus.
    With both the lens and the body set to auto-focus, focus on something with a lot of contrast like a sign with text and then hold the shutter down half-way to focus on the sign. Then adjust the diopter until everything is in focus.
  6. Seiorai
    Seiorai TPF Noob!
    Sep 1, 2013
    5
    Tried that before these pictures above were taken :( Thanks for the suggestion though! I plan to have mostly landscape shots, so in that case I have to go with Manual...right? Since landscapes have a tendency of driving Autofocus nuts.
  7. cgipson1
    cgipson1 TPF Noob!
    Aug 18, 2011
    17,145
    4,355
    I would suggest reading your manuals... both for the lens and the camera body.
    As mentioned... you are in manual focus mode. That means YOU have to focus it or it will not be sharp. Turn it to Auto Focus (switch on both the lens and the body) so that the Lens will Autofocus for you... otherwise... Blurriness.
  8. cgipson1
    cgipson1 TPF Noob!
    Aug 18, 2011
    17,145
    4,355
    NO.... AF works very well for landscapes. I usually use spot focus, so I can tell the camera WHERE I want to focus. Others use other modes....
  9. Seiorai
    Seiorai TPF Noob!
    Sep 1, 2013
    5
    Lenses didn't come with a manual unfortunately, and there is only a brief mention of them in the camera one. I tried looking their manual up on Google but only found their Wiki page. And I did focus manually, for each shot I rotated the lens so as to get the clearest view in the viewfinder, THEN press the shooting button. Is that the wrong way to do it?
  10. cgipson1
    cgipson1 TPF Noob!
    Aug 18, 2011
    17,145
    4,355
    Again.. until you learn what you are doing... just put it in Autofocus. It works!
    Check the diopter, and make sure it is set correctly. If you are going to shoot in manual focus....use the viewfinder, not the LCD. Make sure you have adequate light. If you wear glasses... wear them, and make sure that you can see ok with them. Try something easy first... get something high contrast, like a coke can or something... (something with vastly differing colors and sharp edges at the color change). Or print out a Focus target Free Lens Focus Chart - VFGadgets.com. Put it ten feet (3 meters) away from you... practice focusing on it. Keep your shutter at 1/125 to 1/250 or even faster.... 100, 200 or 400 ISO. Aperture (not wide open as that will not have maximum sharpness... try F8, and adjust ISO as needed). Take a shot... look at it on a computer screen... the small LCD on the camera can be misleading.... try different distances.... try different focal lengths. Also try some of the same exact shots in AF... that will tell you if you are messing up, or if there is a bigger problem.
    adjust as needed.... shoot some more.
    When shooting in manual focus, try to find something in the FOV that you can clearly see... that you can get a good solid with.
    Is this your first DSLR?
  11. cgipson1
    cgipson1 TPF Noob!
    Aug 18, 2011
    17,145
    4,355
  12. Seiorai
    Seiorai TPF Noob!
    Sep 1, 2013
    5
    Alright, I'll try AF first.
    Already checked the diopter, before shooting these as I mentioned before. Never used the LCD, just the viewfinder. Not wearing glasses, and vision is perfect (checked it 3 months ago). The chart seems very helpful, I'll give it a try - thanks for that.
    Yes, as I mentioned in the first message I just bought it a few days ago, and I am completely new to digital photography in general.
    Thanks a bunch for the links. I have no filters whatsoever, and I'll look up Spot Focus and see what it means.
images are comming blur in my nikon 3200
nikon d3200 blurry
nikon d3200 blurry images
nikon d3200 blurry photos
nikon d3200 blurry pictures
nikon d3200 photos blurry
nikon d3200 pictures are blurry
nikon d3200 pictures blurry
nikon d3200 taking blurry pictures
why is my nikon d3200 blurry
