Nikon D40X
Discussion in 'Photography Beginners' Forum' started by photognewbie, Aug 8, 2007.
  1. photognewbie
    photognewbie TPF Noob!
    Aug 8, 2007
    31
    Ive been shooting with an older Sony for awhile now and finally have convinced the hubby i needed something new. So tomorrow my D40x will arrive from the man in the big brown truck...
    Any tips or pointers..good lenses to get etc. I know it will be way different from the Sony
  2. NikonD40x@Denver
    NikonD40x@Denver TPF Noob!
    Jul 8, 2007
    231
    Denver, Co
    get the 55mm-135mm or better, we have the 18mm-55mm and wish we had more
  3. three_eyed_otter
    three_eyed_otter TPF Noob!
    Jul 2, 2007
    244
    Did you order just the body or do you get a kit lens as well?
    have a good one
    3Eo
  4. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Now if you only had the 55-135 you'd be suggesting getting the 18-55 ;)
    Covering the range is important. Covering the range with a single lens is a recipe for bad quality images. Remember that when that 18-200mm lens takes your fancy.
  5. photognewbie
    Aug 8, 2007
    31
    It comes with 18-55mm f/3.5 - f/5.6 ED AF-S DX Zoom-Nikkor lens Basically i know nothing about lenses. Im in the learning process
  6. Chris of Arabia
    Chris of Arabia Herding cats since 1988... Supporting Member
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    It would help if we knew what area of photography you're likely to involve yourself in most, though I'm guessing looking at your zebra photo, that perhaps wildlife is an interest.
    What I'd suggest though is to spend a little time with the kit lens and get used to the camera first. Use the time to find out what sorts of shots you can get with it and crucially, what you'd like to be able to shoot successfully but can't. Use that as your guide to where you need to expand your gear.
  7. alrey
    alrey TPF Noob!
    Aug 7, 2007
    60
    Also something to keep in mind is that your D40X does not have an internal drive motor for autofocus, meaning those Sigma and Tamron lenses you're seeing with the same focal ranges for half the price will be manual focus only on your body.
    If you want to use autofocus, and especially if you are just getting into interchangeable lens cameras, make sure you get Nikkor lenses with "AF-S" in the title.
    That said, a good compliment to your 18-55mm would be the 55-200mm found here:
    [ame]http://www.amazon.com/Nikon-55-200mm-4-5-6G-AF-S-Nikkor/dp/B000O161X0/ref=sr_1_1/105-3056214-2524420?ie=UTF8&s=photo&qid=1186665178&sr=1-1[/ame]
    And for a Nikkor lens with AF-S and VR, $250 is a great price.
  8. photognewbie
    Aug 8, 2007
    31
    Thanks for the tips. Much appreciated
