Nikon D50 slr question
Discussion in 'Beyond the Basics' started by ceres, Feb 7, 2006.
  1. ceres
    ceres TPF Noob!
    Feb 7, 2006
    13
    This is my first time using a digital SLR, I got this one for Christmas and I have no idea what I am doing. I didn't expect it to be much different than a 35mm film camera but here is the problem.... almost every picture looks like it has been stretched vertically. IE if I take a picture of my son then his head looks really tall..... everything is thin.... the closer up I am, the worse it gets.
    First I was working with manual, but now I have it on automatic and nothing makes a difference....
    :confused:
  2. JonMikal
    JonMikal TPF Noob!
    Jul 28, 2004
    12,262
    327
    what software are you using to process your images?
    are you shooting the kit lens at the wide angle setting for all these shots?
  3. ceres
    ceres TPF Noob!
    Feb 7, 2006
    13
    Software.... I tried three different softwares that I have around the house and it looks the same on all of them. The one I installed and tried today is called "Jasc Paint Shop Photo Album 5"
    Oh and about the lens.... I don't know.... :/
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Can you post an example?
    There will be some distortion with the kit lens, especially when at the widest setting. Also, the closer you get, the worse it gets.
    Try standing back and zooming in.
  5. fotogenik
    fotogenik TPF Noob!
    Jan 16, 2006
    345
    Louisville, Kentucky
    Do you mean in the LCD or when you look at them on your computer?
  6. ceres
    ceres TPF Noob!
    Feb 7, 2006
    13
    When I look at them on the computer.... and apparently what program does not matter. I just looked at them on my camera again and they look normal.
    I looked through all of the options that I could on the computer and could not find one that said if I had it at the "widest" setting. :(
  7. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    If they look ok on the camera, then it must be the software your using. One way to check (presuming your on pc with fairly recent os, and shooting jpg) is to open the folder the images are in and right click one, then go to 'open with' and choose 'windows picture and fax viewer'. This should open the image in the viewing software and will be proportional. If its ok there, you know its the software settings your using. Hope this helps
  8. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Do you have a program that shows all the camera data with the image? Each image has that info built into it.
    Aperture, Shutter speed, ISO setting etc. You are looking for focal length. If it's says 18mm, then you shot with the widest setting (assuming you have the kit lens)
    You should also be able to see this info when viewing the images on the camera.
  9. ceres
    ceres TPF Noob!
    Feb 7, 2006
    13
    And until today, I could.... but some goddamn button I hit turned it off and now it has some weird ..... the only way i can describe it is mountains.... it looks like sound. This makes me want to go back to film :meh:
  10. ceres
    ceres TPF Noob!
    Feb 7, 2006
    13
    I looked at it in windows picture and fax viewer and they were scewed.... doh
  11. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Thats your histogram, if you push the up and down buttons (on the round control pad) it displays different info.....just keep presing untill you gat to the info. I'm affraid you've lost me with the computer thing tho...sorry.
  12. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Maybe you should read though the manual.
