Nikon D5100 Only one Dial?
Discussion in 'Nikon Cameras' started by DGMPhotography, Apr 16, 2012.
  1. DGMPhotography
    DGMPhotography No longer a newbie, moving up!
    Mar 23, 2012
    2,189
    435
    Richmond, VA
    Okay, so I have a dial that controls shutter speed, but what about aperture? I thought aperture control could be independent of the zoom level of the lens, but it appears I can only change my aperture by zooming in and out. Maybe this is how it's supposed to be? I'm not sure, I'm new to photography, but I've handled other cameras which have a dial for both. Help?
    Thanks!
  2. Derrel
    Derrel Mr. Rain Cloud
    Top Poster Of Month
    Jul 23, 2009
    36,810
    13,505
    USA
    You press a small button and hold it in, then use the thumb wheel to shift aperture wider or narrower. When the small button is released, the thumb wheel goes back to adjusting the shutter speeds.
    A variable maximum aperture lens when zoomed in and out will often (but not "always") cause the aperture to shift. But rest assured, there *is* a system that allows the thumb wheel control to adjust the aperture on lower-level Canon and Nikon bodies!
  3. MTVision
    MTVision Been spending a lot of time on here!
    Aug 1, 2011
    3,008
    527
    Vermont, US
    Reading the manual is super helpful.
    In manual mode hold done the +\- button and spin wheel to change the aperture. In aperture priority model the wheel controls aperture.
    You can change the aperture by zooming in ad out because the lens has a variable aperture - meaning the aperture changes based on the focal length.
  4. KmH
    Apr 9, 2009
    38,754
    5,162
    Iowa
    All of the 'compact' Nikon entry-level cameras - D40, D40x, D60, D3000, D3100, D5000, D5100 only have the one Command wheel.
    As mentioned holding down the +/- button there near the shutter release, while turning the command wheel adjusts the lens aperture.
    When you read the user's manual be sure and make note of the 3 metering modes, 3 auto focus modes, 3 auto-focus area modes, range of white balance settings, flash control settings, and picture control settings you have available. In addition, your D5100 can display a histogram on the rear LCD you can use to evaluate the exposure distribution in your photos.
  5. DGMPhotography
    Mar 23, 2012
    2,189
    435
    Richmond, VA
    Thank you all so much!!! :D
  6. greybeard
    greybeard Been spending a lot of time on here!
    Dec 30, 2011
    3,039
    577
    WV
    The ISO selftimer custom mod is easy and very useful.
change aperture nikon d5100
change aperture on nikon d5100
how do you change how to change aperture on nikon d5100
how do you change the aperture on a nikon d5100
how to adjust aperture nikon d5100
how to change the aperture on a nikon d5100
how to slow down shutter speed on nikon d5100
how to take photos in aperture mode with a d5100 nikon
how to use manual mode on nikon d5100
