Nikon D610 thoughts?
Discussion in 'Nikon Cameras' started by DreamCatcher, Sep 18, 2017.
  1. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    Yes would be their entry level camera. The D750 has some better camera features, but the sensor scores slightly lower in terms of output. And of course it's quite a bit more expensive. It may not have the AF system of the D500 or D750 and higher bodies. But it's low light ability is only beaten by a couple cameras that are more expensive. For fast action in good to decent light, no probably not the best camera to have. But for $1,000 it's a very good camera.
    • Agree Agree x 1
  2. benhasajeep
    May 4, 2006
    4,021
    494
    Don't know if your willing to do Ebay. But D800's are down to around $1,000 to $1,200. Low shutter count one on there now for less than $1,000. 18k clicks on it.
    • Like Like x 1
    • Informative Informative x 1
  3. DreamCatcher
    DreamCatcher TPF Noob!
    Sep 16, 2017
    18
    Isn't eBay a little bit of gamble?
  4. benhasajeep
    May 4, 2006
    4,021
    494
    I have had good luck so far.
    Was just going to post there is a D610 ending in about an hour from now 8:28 eastern. $799 right now. 12k clicks on it. Seller says bought from Keh rated as EX. If it really came from KEH. It's a good camera.
  5. benhasajeep
    May 4, 2006
    4,021
    494
    Brand new D610 USA with warranty for $1,029! Ebay!
  6. DreamCatcher
    Sep 16, 2017
    18
    I'm going to have to look into that then. Thanks for the info I was always told to be careful with eBay stuff.
  7. benhasajeep
    May 4, 2006
    4,021
    494
    Yea, I don't go in blind. I check the feedback. Not just to see it's high number of positive, but actually check what they had been selling. I had to file once on a person, for a drywall lift of all things. Was never shipped. I got my money back.
  8. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,511
    15,225
    USA
    I bought my D610 used with the MBD-14 battery grip, th5ree Nikon batteries, a body cap, and 4,812 actuations, all for $849 at my loal store, so my negative impressions of it were not influenced by having payed a high price for the camera and grip; I bought it at a fantastic price, in great condition, but the number of failures to focus that I get with it during the course of a day spoils multiple shot opportunities every single day, and the need for a blinding white-light AF assist when a 12-year-old Nikon like the D2x can LOCK focus in 1/4 second with the same, old, slow lenses...shows me that the D610 is built around a crap AF module.
    As braineack says, I'm spoiled by "real cameras" that can LOCK focus in an instant, 99.9 percent of the time.
    AF-I for example on the D610...wow...what a useless "feature". Screws up a lot. A Mom and Dad camera feature.
    In all fairness, the D610 is a "mom and dad" camera...I'm coming from pro-level Nikons that date back to 1998...the AF performance is really,really WEAK in this camera with consumer of slow-f/stop zooms, and is only marginally better with the 85,50,and 180mm primes, which are f/1.8, f/1.8, and f/2.8 lenses.
    Failures to focus on OBVIOUS targets like seagulls in flight at 5,8,10,12,15 meters with a 70-300 in BRIGHT mbeach sunlight...failure to achieve focus on aircraft in plain, blue skies...failures to focus fast and reliably on all sorts of subjects...just crappy AF performance. In even moderate light with a 50mm or 85mm prime Nikkor lens, I constantly find the D610 to be BLASTING a white beam of light in order to achiev a focus lock! Unacceptable to me when a 2005 or 2009 Nikon body can LOCK focus with the SAME, exact lenses I have had for years...with no annoying white flashlight beam!
    Gotta keep in mind, the D610 **is** an entry-level full frame, and was derived from the D600, which was built on the APS-C D7000 body; a amra that was plagued with focusing issues, the D7000 was. If this is the first AF d-slr you've had, you might feel that it's a solid camera, but I have to rate it as just acceptable...it's wayyyyyy less-reliable than a higher-end Nikon with a powerful AF module.
    Again: the white AF assit light Nikon put into the D610: that is the mark of an older camera, something like a 2003 Fuji S2 Pro or something like that, meaning a $389-level consumer body...
  9. Peeb
    Peeb Semi-automatic Mediocrity Generator Supporting Member
    Jul 16, 2015
    2,786
    1,749
    Oklahoma
    I wonder if you got a bad copy?
    I shot my D610 with a 200-500 plus 1.4x TC and had no trouble capturing seagulls in flight at a local lake; and TRUST ME, Derrel is a much (much much) better photographer then I am.
  10. Derrel
    Jul 23, 2009
    40,511
    15,225
    USA
    I don't think it's a bad copy; any camera that needs a white AF assit beam to hit focus means the AF module is weak. Compare it to a D1,D1h,D2x,or D3x and it's just clearly a Mom and Dad level camera. It's a big step down from what I expect a 24-MP camera to be. The fact that the body and grip have a gap and sloppy fit, and the viewfinder is only so-so...this is a $380-type Nikon body. This is a cheap body camera.
    Compare the way this thing shoots and respoinds to the 2004 D2x or the 2009 D3x...there';s just no comparison.
    Selling the D3x was the biggest photo mistake I have made in a decade and a half. It was a fantastic camera. it flubbed maybe one shot out of 1,000...this one? 15,20,25 shots out of 1,000, every day it's used.
  11. Peeb
    Jul 16, 2015
    2,786
    1,749
    Oklahoma
    OK- I'll agree that if 97.5% to 98.5% capture rate is a big step down from 'better' nikons, then you probably have a representative copy of the D610.
    In large part due (no doubt) to my poor technique and skill, I'd be thrilled with a 5% 'miss' rate!
  12. goodguy
    goodguy Been spending a lot of time on here!
    Dec 5, 2012
    5,545
    1,113
    Toronto Canada
    D610 is good as a basic full frame camera, the sensor on it is superb, my advise since the AF system isn't amazing maybe spend a little more and get the D750, I have this camera for 3 years, its AF system is excellent, I find the D750 has very few weaknesses.
news
nikon d610 mpb
