goodguy
- Joined
- Dec 5, 2012
- Messages
- 5,555
- Reaction score
- 1,121
- Location
- Toronto Canada
- Can others edit my Photos
- Photos OK to edit
Very good example of the true power of modern Sony sensor, not only its very good in low light but the amount of DR is insane!!!My girlfriend wanted photos of the house lit up so last night I took a few with my D750.
Before:
After +2.6 exposure in LR:
Crop of after:
If the D610 has anywhere near this DR, then the only level the 6D and D610 would be on is based on marketing.
Also it used to be that lenses were more important than a camera body and that was that. There wasn’t much to a camera back in the film days. After the advent of DSLRs and when cameras became small computers, the bodies tended to matter a bit more but still not as much. Now a good body can mean as much as a lens depending on what you’re doing. I’d still rank the importance of a lens higher but going from one body to the next depending on sensor size and body age can mean a lot faster and accurate AF, way better dynamic range, and more features that may or may not matter to the type of photography you do.
The D610 sensor is actually located ever so slightly above the D750, only one point so it doesn't mean anything but still the D610 sensor is just as good as the one on the D750, the D750 advantage over the D610 is in other areas including the new processor that lets you use a higher native ISO of 12800 rather then the highest on the D610 6400ISO and lots of other goodies.
