Nikon D80 advice
Discussion in 'Photography Equipment & Products' started by Nikklaus, Jun 7, 2007.
  1. Nikklaus
    Nikklaus TPF Noob!
    Jun 6, 2007
    34
    I'm new to DSLR's, but I think I know the basics. I plan on getting a D80 when I've saved enough, but I don't really know the best lens set up to go for. I was originally thinking of getting it with the 18-135 lens kit, but I was advised against it and told that an 18-55mm with a 55-200mm would be a better set up. I don't want to be able to take a certain type of photo in particular (like macro) - I would just like a versatile set up at first, though in the future I wouldn't mind trying differents styles.
    I guess I'm not 100% set on the D80, so if someone thinks I'm making a mistake by getting one I'm definitely open to advice, but I like the specs because I need to be able to take high-res photos for Graphic Design work I do, and I get the impression that they're pretty good. Also, any advice on accessories you think I should go for is very welcome.
    Cheers
  2. theusher
    theusher TPF Noob!
    Jan 17, 2007
    250
    Nowhere
    The D80 is a great camera. Very nice feeling in the hand, very solid. I opted out for the kit lens, and instead went with a Sigma 17-70mm 2.8-4.5. It is able to do very close macros, I like the lens a lot. IIRC the lens was around $400. Sometimes I do regret having not gotten something with more versatility like the 18-200 VR from Nikon, but as you were saying I'll just get something in between like 50-200 or 50-300.
  3. Nikklaus
    Nikklaus TPF Noob!
    Jun 6, 2007
    34
    What kind of pictures are you unable to take with a lens like that? The Nikon 18-200mm VR is £549.99 over here, which is pretty expensive - so I'd like some alternatives, but if it turned out to be definitely worth it I could probably stretch to it. Has anybody had experience with the 18-135mm kit lens?
  4. Mike_E
    Jan 26, 2007
    5,327
    266
    Nikklaus, you can get extension tubes for around $15 US to fit between your lens and camera that will make a great macro set up!
    The D80 will do you fine. :)
    mike
  5. gubak
    gubak TPF Noob!
    Sep 29, 2006
    11
    18-200 VR from Nikon is very good solution. I use it as well!
  6. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,699
    68
    Missouri
    I agree on the 18-200 VR, lovely lens, but harder than heck to find and expensive as well.
    I don't care for the 18-135 kit lens, for $300 US you can do a LOT better... basically, for the same money you can get the 18-55 and the 55-200 VR, have a wider range focal lengths AND VR on the long end where you need it.
    The 18-55 kit is not a macro lens, but you can shoot very close with it...
nikkor 50-200 vs nikkor 50-300
nikon 50-200 vs 50-300
photography with nikon d80 50-300 lens
