Nikon D80 or D90
Discussion in 'Photography Equipment & Products' started by mikerev, Oct 18, 2008.
  1. mikerev
    mikerev TPF Noob!
    Oct 18, 2008
    So I'm looking gor a DSLR. I've been shooting on a borrowed D50 for some time now, and i think i want to stick with nikon. Am i better off going for the D80 and spending the savings on lenses, or getting the D90 and having less money for lenses?
    D80- 600 euros
    D90- 999 euros
    Both are body only
    Any help/advice would be appreciated
  2. dmatsui
    dmatsui TPF Noob!
    May 7, 2008
    106
    Middelburg, The Netherlands
    I think most people here are going to tell you get the D80 and spend more money on the lenses. I have the d80 and i'm very happy with it (though to be honest i dont have any experience with any other dSLR)
  3. tirediron
    Jul 8, 2005
    40,900
    12,418
    Victoria, BC
    They will also tell you that cross-posting isn't considered appropriate.
  4. mikerev
    mikerev TPF Noob!
    Oct 18, 2008
    Eh, yeah, my bad. Sorry. I can't figure out how to delete this one. I posted it here by accident, then couldn't find it in the forum i meant to post it in, so i did it again.. Sorry :(
  5. shivaswrath
    shivaswrath TPF Noob!
    Sep 18, 2007
    302
    Norwalk, CT
    I would disagree.
    D90 is far superior in its innate matrixing and WB abilities; the D80 has become a bit of a relic in comparison.
    Updates to menu's and the sensor are also a plus in favor of the D90.
    I realize Euros 400 is a huge difference and potentially means at least 2 non-pro lenses or 1 pro lens, BUT, you'll end up wanting to upgrade as soon as you REALLY get into shooting.
    You should try both of them out to get a feel for the technology differences. I was astonished with the D300 after using my D40x for awhile, the sensor and matrixing are some much more robust; why do I throw my D40x in the mix? The same sensor as the D80. . . .just food for thought. . .(especially since the D90 is apparently more "advanced" than the D300 in its tech abilities)
  6. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    If you can swing it, get the D90.
  7. photogmatt
    photogmatt TPF Noob!
    Nov 15, 2007
    66
    Agree totally, I'm replacing my D80 with a D90. I considered going with the 300, but I'd rather spend the $500 toward a lens. The only thing the 300 has over the 90 is the weather sealing, and the focus points it seems.
  8. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    Twas me, I'd go with the D90 and worry about the extra lenses later.
  9. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    The D300 has more dedicated controls as well, but the D90 is getting closer.
  10. MarkCSmith
    MarkCSmith TPF Noob!
    Jul 19, 2007
    139
    4
    Toronto, Ontario, Canada
    Really depends how serious you are about photography. If it's a hobby, then just stick with the D80 and get some extra lenses, you'll have to get some experience before you can really tell the difference between the top tier cameras anyway. If you're a serious photographer, you wouldn't be asking such a vague question on the forum :D
  11. amba
    amba TPF Noob!
    Jun 14, 2008
    43
    I'd say plan your budget so that you can spend on lenses at a minimum, as much as you plan to spend on the body. Until you can reach that point there's no sense in going for the more expensive body.
    The D80 is a prefectly good body, sure the D90 has its advantages, but, at least in my mind, unless you already own some very good lenses, you'll get a better return for your money if you spend the extra 300 on lenses than on the better body.
    Here's what glass I would make sure I have before upgrading a body:
    Nikkor 35mm f/2.0
    Nikkor 18-55/70/135/200mm VR zoom lens
    Superwide angle zoom:
    - Nikon 12-24mm f/4, or
    - Sigma 10-20mm f/4-5.6
    If you're into tele angles (I am not..) also
    - Nikon 70-200 f/2.8 VR
    It's a matter of taste, but as I said... I own a D70 and don't plan to upgrade it before I spend $1~2K on lenses that I really want.
    Of course many good lenses are worthless unless you're set up to have them ready when you need them (e.g. if you are travelling a lot, and cant or don't want to carry all that gear with you). If this is the case, than getting just one good all-around lens and the more expensive body would make more sense.
  12. ionz13
    ionz13 TPF Noob!
    Oct 15, 2008
    9
    Los Angeles
    As a friend advised me, if you can afford the better body, then go for it!
    If you're on a budget, then stick to your budget and no more.
