Nikon D90 FE E error message
Discussion in 'Digital Discussion & Q&A' started by quinte, Sep 23, 2010.
  1. quinte
    quinte No longer a newbie, moving up!
    Sep 23, 2010
    231
    63
    Arkansas
    I recently purchased a Sigma 50mm 2.8 EX DG 1:1 Macro Lens on ebay. Have not had chance to use much. The other day trying it out in auto and manual- all seemed to be working ok. Today tried again. Played around in auto, then switched camera and lens to manual. When I unlock the aperture ring and go to anything other than f32, I get an FE E message. I can use the command wheels on the camera and manually change speed and aperture that way, but shouldn't I be able to use the ap ring on the camera? Making any sense? I also cleaned the lens and camera contacts and tried reseating the lens several times. Thanks
  2. ajkramer87
    ajkramer87 TPF Noob!
    Jan 7, 2010
    443
    York PA
    You have to leave it locked in at f/32. You change the aperture via camera.
  3. quinte
    Sep 23, 2010
    231
    63
    Arkansas
    Thanks. I finally figured out that was the only way to get it to work manually. I just thought that I had used the aperture ring when I first got it, but I must have been thinking of a different lens. I'm just glad to know that all is working ok. I suppose the aperture ring could be used on a different camera and not the D90 or why would they put it on there?
