voodoocat said:I don't think the F100 has a color matrix meter like the F5. It might also be a sturdier cam. I've heard you can drop the F5 from a building and it'll still work.
somewhere said:The F5 comes with three new light meters. The familiar Nikon Matrix meter has undergone a transformation and is now a 3D color Matrix meter with a 1,005 pixels (they used to be called "segments"); the center-weighted meter has become the world's first variable size center-weighted meter; and the spot meter has grown to become five spot meters.
With 1,005 pixels in the Matrix meter's sensing array, the meter is designed to provide an enormous range of detection for brightness and contrast patterns; the pixels also measure RGB color, and thus take the color in a scene into account when making the exposure. The RGB sensors can also tell if fluorescent or tungsten light is in use. Adding color detection to the metering process gives the meter additional information for the most accurate scene identification. "In situations in which you'd normally have to compensate for color, the camera does it for you," said a Nikon spokesperson. "Taking into account light, distance and color, it's the most accurate automatic light meter ever created."
well said I was about to say that..I made a research about this on the net..F5 is used by professionals in war zones, they will go on ticking an take the licking, that and some special features is what you pay for. For regular normal use my N80 never let me down, I knokced it about a bit too. The F100 you can knock about a bit more.
The F5 would probably be the last 35mm film camera you would ever need to buy.
