I am getting pretty close with stuff like lizards and tortoises I own or in the wildLots, but it depends greatly on what sort of wildlife (as in how "close" you want to get, and how much you have to spend. Wildlife lenses can be anywhere from $500 to $15,000.
for tortoises you won't need much reach, you can approach them and it's not like they'll move and even if they did they can't outrun you, but you'll really need sharpness, contrast and color. The coloring on a tortoise can really start to blend together on a mediocre/bad lens, their coloration and texture is really quite subtle. They also tend to be in areas with little light or laying in the sun with glare coming off their shells. My recommendation then would be a standard tele zoom that gets down to f/2.8 and a good polarizing filter (to cut the glare off their shells when they lay in the sun). If you're primarily shooting them on land, and not on logs in the river, you can probably even get away with a mild tele prime, like a 50-100mm.
What type of camera are you currently using?
Yeah, don't think OP would be going wrong either way.for tortoises you won't need much reach, you can approach them and it's not like they'll move and even if they did they can't outrun you, but you'll really need sharpness, contrast and color. The coloring on a tortoise can really start to blend together on a mediocre/bad lens, their coloration and texture is really quite subtle. They also tend to be in areas with little light or laying in the sun with glare coming off their shells. My recommendation then would be a standard tele zoom that gets down to f/2.8 and a good polarizing filter (to cut the glare off their shells when they lay in the sun). If you're primarily shooting them on land, and not on logs in the river, you can probably even get away with a mild tele prime, like a 50-100mm.
Yeah, that's an excellent point, and one I considered. If the OP is primarily shooting tortoises that he can get pretty close to, then you are absolutely right, probably better to go with something with less reach that's a little faster lens.
I decided to recommend a general wildlife lens on the basis of this:
But I think I misinterpreted that comment. I read it as "lizards and tortoises I own" OR other stuff "in the wild."
Now that I've looked at again, I think you are closer to the mark. It sounds like he primarily wants pictures of lizards and tortoises, and with both of those, you want to be able to get fairly close, so perhaps a faster lens with less reach. Even a 70-200 f/2.8--I bought my Tamron 70-200, used, for under $1000 and have been thrilled with it.
Nikon D3300for tortoises you won't need much reach, you can approach them and it's not like they'll move and even if they did they can't outrun you, but you'll really need sharpness, contrast and color. The coloring on a tortoise can really start to blend together on a mediocre/bad lens, their coloration and texture is really quite subtle. They also tend to be in areas with little light or laying in the sun with glare coming off their shells. My recommendation then would be a standard tele zoom that gets down to f/2.8 and a good polarizing filter (to cut the glare off their shells when they lay in the sun). If you're primarily shooting them on land, and not on logs in the river, you can probably even get away with a mild tele prime, like a 50-100mm.
Tamron 60mm f/2 would be a great option. Ultra sharp DX lens that would really capture lizard scales and tortoise shells. It'll do macro as well, so you could really get in close to your pets, really nail that eye detail.Nikon D3300for tortoises you won't need much reach, you can approach them and it's not like they'll move and even if they did they can't outrun you, but you'll really need sharpness, contrast and color. The coloring on a tortoise can really start to blend together on a mediocre/bad lens, their coloration and texture is really quite subtle. They also tend to be in areas with little light or laying in the sun with glare coming off their shells. My recommendation then would be a standard tele zoom that gets down to f/2.8 and a good polarizing filter (to cut the glare off their shells when they lay in the sun). If you're primarily shooting them on land, and not on logs in the river, you can probably even get away with a mild tele prime, like a 50-100mm.
Great lens, but it won't autofocus with your camera. You can't autofocus with "D" lenses with your camera.What do you guys think of this for sharp pics
Nikon AF NIKKOR 50mm f 1.4D Autofocus Lens 1902 B H Photo Video
With your d3300 you would have to get this version of that lens ==> Nikon AF-S NIKKOR 50mm f 1.4G Lens 2180 B H Photo VideoWhat do you guys think of this for sharp pics
