Nikon not capturing images
Discussion in 'Beyond the Basics' started by gabelimom, Jan 14, 2010.
  1. gabelimom
    gabelimom TPF Noob!
    Jan 12, 2007
    90
    Hi everyone-
    I just took out my D70 to take some shots, and while the AF is working, the flash is firing, the image is not coming up in the LCD, nor is the counter number changing. I changed memory cards, thinking that it was defective, but the camera is doing this with other cards, too. Is there a quick fix or (sigh), does it have to go in for repair? I'm no longer under warranty, and I'm wondering if this is a sign that I should upgrade.
    Thanks in advance to everyone for their help and advice. :)
  2. Derrel
    Derrel Mr. Rain Cloud
    Top Poster Of Month
    Jul 23, 2009
    36,847
    13,530
    USA
    This does not sound like a good situation. Have you tried formatting the card with a two-button, in-camera format on the D70??? It sounds like the sensor might be kaput...
    but you know, there *can* at times be problems with the memory card that will prevent the D70 from writing files, like when the camera switches folders, to a new folder, I have had some problems over the years with my D70 NOT writing files to the card.
    My best suggestion is to format the CF card in the D70,using the two buttons with the red writing on them, and then see if it will shoot an image and record it to the CF card.
    Make sure the exposure is appropriate to the situation, and see if the file is written. if not, then I would suggest having a knowledgeable camera store employee take a look at it,and if it's a no-go, then it will have to be sent in for an estimate.
    If the sensor needs to be replaced, I would say it's not even worth it on a D70 body these days, with the purchase price of used ones in the $200-$250 range.
  3. gabelimom
    gabelimom TPF Noob!
    Jan 12, 2007
    90
    I formatted two cards, thinking that maybe I fried one. It's not capturing on either card. There were signs, though, that something was awry. When I last used the camera, some of the images were coming out purple, and some came out completely corrupted (broken into four quadrants, and purple, too). This was right before last night, when it took 3 photos and then stopped.
    When I formatted the card again, it said on the LCD, "This card cannot be used."
    I've had the D70 for at least 4 years now, and have used it ALL THE TIME. It was inevitable that it would break down. My fear, as you wrote, is that it won't be worth it to repair and I'll have to get a new camera. Would I need a new body only, or should I replace the whole thing?
    And you're right about the cost. I just checked; to repair it would cost about $250, which is the same as getting a used body.
    Sigh. I'm trying to be positive about the situation, but this is not going to be a cheap fix. :(
  4. bhphotography
    bhphotography TPF Noob!
    Oct 9, 2009
    274
    Ottawa, Ontario
    Definitely sounds like a sensor / shutter problem.
    The "non pro" bodies aren't rated for as many actuations as the pro bodies, so if you used it regularly for 4 years, I would say it's reached it's limit.
  5. KmH
    Apr 9, 2009
    38,777
    5,168
    Iowa
    If you checked with Nikon Service USA, it seems that $250 is a minimum charge.
    What did whoever looked at the camera, determine needed to be replaced?
    You might include some geographical location info in your profile to make some kinds of recommendations easier for other members to offer you.
    You have these Nikon Authorized Repair Station options:
    * = Nikon COOLPIX Digital Camera Trained Authorized Repair Stations
    + = Nikon AFS Lens Trained Authorized Repair Stations
    • Nikon Authorized Repair Stations (NARS)
    C.R.I.S. Camera Services * +
    250 North 54th Street
    Chandler, AZ 85226
    480-940-1103
    Fax: 480-940-1329
    So. Photo Tech Service Inc.* +
    37 N.E. 167th Street North
    Miami, FL 33162
    305-653-7355
    Fax: 305-653-7356
    So. Photo Technical Service Inc.*
    527 N. Polk Street/PO Box 189
    Pineville, NC 28134
    704-889-7040
    Fax: 704-889-7042
    California Precision Serv. Inc.
    (Profoto)* +
    1714 28th St.
    Sacramento, CA 95816
    916-451-1330
    Fax: 916-451-7460
    (Satellite)* +
    2275 S. Federal Hwy., #330
    Delray Beach, FL 33483
    561-272-2306
    Fax: 561-272-9681
    Albuquerque Photo-Technologies* +
    6609 Menaul Blvd. NE
    Albuquerque, NM 87110
    505-881-6600
    Fax: 505-881-6606
    Kurts Camera Repair* +
    7811 #P Mission Gorge Rd.
    San Diego, CA 92120
    619-286-1810
    Fax: 619-286-6093
    Camera Service Company* +
    4391 Atlanta Rd.
    Smyrna, GA 30080
    770-432-4257
    Fax: 770-432-4258
    Photo-Tech Repair Service Inc.* +
    110 E. 13th St.
    New York, NY 10003
    212-673-8400
    Fax: 212-673-8451
    Authorized Camera Service* +
    21250 Califa St., Suite 110
    Woodland Hills, CA 91367
    818-340-0582
    Fax: 818-340-0586
    Peachtree Camera &
    Video Repair* +
    562 Wylie Rd. Suite 4
    Marietta, GA 30067
    1-888-539-7824
    Fax: 770-795-8030
    Associated Camera Repair Inc.* +
    3401 N.E. Sandy Blvd.
    Portland, OR 97232
    503-232-5625
    Fax: 503-236-2421
    Pro Camera Service Inc.* +
    710 E. Thousand Oaks Blvd.
    Thousand Oaks, CA 91360
    805-497-7240
    805-497-0826
    Authorized Photo Service* +
    8125 River Drive, Suite 100
    Morton Grove, IL 60053
    847-966-4091
    Fax: 847-966-4101
    Precision Camera
    & Video Repair, Inc.* +
    3 Anngina Drive
    Enfield, CT 06082
    800-665-6515
    Fax: 860-763-7100
    United Camera & Binocular
    Rpr. Corp.* +
    1062 Tower Lane
    Bensenville, IL 60106
    630-595-2525
    Fax: 630-595-2526
    Havel Camera Service Inc.*
    1102 Basse Rd.
    San Antonio , TX 78212
    210-735-7412
    Fax: 210-734-2715
    Metro Camera Service Inc.* +
    330 West Hampden Ave.
    Englewood, CO 80110
    303-934-2471
    Fax: 303-935-5854
    Pho-Tech Service Center* +
    110 N. Main St./P.O. Box 638
    Hesston, KS 67062
    620-327-2190
    Fax: 620-327-3036
    Forster's Camera Service Inc.* +
    40 West 2950 South
    Salt Lake City, UT 84115
    801-487-1288
    Fax: 801-487-1350
    Strauss Photo-Tech Services Inc.* +
    1240 Mt. Olivet Road NE
    Washington DC 20002
    202-529-3200
    Fax: 202-526-6465
    Sanford Camera Repair* +
    1056 Massachusetts Ave.
    Arlington, MA 02476
    781-648-2505
    Fax: 781-648-2508
    Midwest Camera Inc.* +
    318 Oak St.
    Wyandotte, MI 48192
    734-285-2220
    Fax: 734-283-7478
  6. JLEphoto
    JLEphoto TPF Noob!
    Nov 10, 2009
    153
    Homestead, FL
    Sounds like it ist time for a D300s.
  7. wgp1987
    wgp1987 TPF Noob!
    Apr 23, 2009
    680
    4
    New Jersey
    Should have gone with a Canon!
    just kidding!
  8. JLEphoto
    JLEphoto TPF Noob!
    Nov 10, 2009
    153
    Homestead, FL
    Them's fight'in words.
  9. gabelimom
    gabelimom TPF Noob!
    Jan 12, 2007
    90
    Thanks so much for all the info!
  10. gabelimom
    gabelimom TPF Noob!
    Jan 12, 2007
    90
    No way! I love my Nikon. I used it incessantly. It was just a matter of time.
  11. gabelimom
    gabelimom TPF Noob!
    Jan 12, 2007
    90
    Thank you again to everyone who responded. I'll let you know if I repair, upgrade or both. I really should have a second body when I go on shoots, anyway. :)
  12. MrRamonG
    MrRamonG TPF Noob!
    Nov 10, 2009
    380
    Anaheim California
    If repair costs the same as a used body, I would say go with repair. If you buy used you may simply inherent someone else's sensor that is about to go kaput or some other not-so-obvious problem. Also, by sticking with your current body you would be well aware of your camera's history.
d80 not writing photo to card
nikon camera not writing to card
nikon d70 camera pictures are coming out red
nikon d70 image is purple
nikon d70 not taking picture
nikon d70 this card cannot be used
nikon d70s this card cannot be used
nikon d80 not writing to card
nikon d80 video purple pictures fix
why wont my nikon d70 take pictures
