Nikon SB-800
Discussion in 'Beyond the Basics' started by ffmedic245, Feb 15, 2008.
  1. ffmedic245
    ffmedic245 TPF Noob!
    Feb 13, 2008
    26
    East Tennessee
    Does anyone have any tips on settings for a nikon SB-800. It always seems to light up the person very well but just about blackout the background. I know a new faster lens would help, but until then?
  2. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    Faster lens will not help that much, you need to expose for the whole area and then adust your flash to add fill light. It can take a bit of practice.
  3. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,340
    16
    Caribbean
    Use a slower shutter speed and a diffuser. Just try to get it to the point where you can see your background, but not any movement around your subject.
    Keep in mind that the hand holding rule kinda goes out the window with a flash, you just have to get the right shutter speed so it looks believable.
  4. notelliot
    notelliot TPF Noob!
    Nov 13, 2005
    827
    i'd recommend bouncing the flash in this situation, when possible. angle the head so the beam hits a point right above the subject, so it falls behind and overhead.
    if you can't bounce off of a ceiling, try a wall.
  5. plastii
    plastii TPF Noob!
    Oct 12, 2007
    317
    Gilberts, IL
    Here is a very interesting PDF file made by Nikon.
    SB-800
    Autofocus Speedlight
    A collection of example photos
  6. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    Delavan, Wisconsin, USA
    The speed of the lens won't make a difference. You need to use a slow enough shutter speed to expose the background and then set the flash to "fill-in" the subject.
    Depending on the type of camera check out your settings for front or rear curtain flash or possibly a fill flash function.
    You may have to set the EV on the flash down 1 or 2 stops depending on the subject and distance from you.
    Assuming your shooting digital, just try a couple of shots, adjusting as you go.
  7. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Learn to use the flash off-camera.
    http://strobist.blogspot.com
