Nikon sharpness adjustments
Discussion in 'Digital Discussion & Q&A' started by PNA, Apr 26, 2008.
  1. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Wave when you see me go by.....
    Today I attempted to test the sharpness attributes of the D70 and concluded there are no differences.....
    Shots of the same subject were taken with tripod and remote triggering to avoid shake.
    Normal
    Auto
    -2
    +2
    Also what sharpness lacking through the camera can be compinsated with PS, right????
    As a result I am satisfied with the Auto setting, but will question higher authority....."youseguys". ;)
    Any comments, suggestions would be appreciated.
    Thanks..............
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    I am not a Nikonian, but any sharpness due to the sharpness attributes of the camera should be also reproducible by setting in-camera-sharpening to zero and doing it later on in PS or other software.
    However, detail lost due to oversharpening of fine structures in-camera cannot be reconstructed later on.
  3. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Hi, Alex.....
    Good point, meaning that the Auto setting should be sufficient?
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    To answer that, I would need to know how conservative "auto" is, which I do not know. If it is rather aggressive, then there might be the danger of losing detail due to sharpening, if it is rather conservative, and prefers "under-sharpening" then you should be fine.
    I personally set my camera (Canon) simply to a low sharpening level and do the final sharpening in PS. I do not have any "auto" setting. ;)
  5. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Yes i think so myself... i have achieved good sharp results with a D50 and kit lens by using sharpening techniques in PP.
    PP is really where you can get the sharpness you want providing the image has no camera shake and is not out of focus.
  6. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Canon????? Hummmm, no Auto??
    And it takes pictures????:lmao:
  7. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    I take the picture ;)
  8. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Woops......:D
  9. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    And damn good ones too....!!!
  10. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    My conclusion also....Thanks.
  11. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,340
    16
    Caribbean
    Are you shooting in RAW? I can't really tell from your description, but if your shooting in RAW, no in-camera processing is done at all. So, no sharpening will be applied.
    Oh, and doing sharpening in PS will make your images look a lot better.
  12. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Yes I shoot in RAW......and thank you for your explanation of the in-camera sharping factor. Makes sense.
adjust sharpness nikon d5100
can you edit sharpness in vanera on nikon d5100
d5100 sharpness setting
how to adjust sharpness in nikon d5100
how to adjust sharpness on nikon d5100
how to change sharpness setting d5100
how to set d5100 camera sharpness
nikon d5100 sharpness
nikon d5100 sharpness setting
nikon sharpening setting
