Nikon SLR's and light seal degradation...
Discussion in 'Collector's Corner' started by AndrewG, May 18, 2008.
  1. AndrewG
    AndrewG TPF Noob!
    May 15, 2008
    155
    Exeter, UK
    How common is this on older SLR's like the FE2 and FM2N and how can a camera be guaranteed/checked for light-tightness other than by running a test roll through it?
    Is a degraded light-seal obvious?
    Thank you.
  2. malkav41
    malkav41 TPF Noob!
    Feb 18, 2007
    317
    South Carolina Boondocks
    Older Slr's and Rangefinder cameras commonly have bad light seals, as the materal the seals are made of turns to a tarlike goo over the years. Usually light seals that have gone bad will leave residue on the edge of the film door, and on the end where the door, and body meet. Also the bumper for the mirror on an Slr can deteriorate depending on what it is made of, but usually needs to be replaced at the same time as the other ones. I hope this helps answer your question.
    You can get a great light seal kit off of E-bay that is sold by a guy that goes by the seller name interslice. He is great, and very helpful.
  3. AndrewG
    AndrewG TPF Noob!
    May 15, 2008
    155
    Exeter, UK
    Thank you.
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
  5. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,746
    42
    Ahwatukee, AZ
    It's a fairly simple and straight forward operation, I have done it many times. Just buy a few sheet of self adhesive foam, cut to dimensions and replace the old one with the new one. Follow the directions given by the sellers and you should be just fine.
  6. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,842
    446
    L.A.
    Manual-focus Nikon SLRs had minimal light seals to begin with. It's unlikely
    you'd find one with a problem in that area.
fe2 light seal
nikon fe light seal replacement
nikon fe seals
nikon fe2 seal replacement
nikon light seal
nikon light seal kit
nikon light seals
replace light seals nikon fe
slr light seals
slr seal material
