Nikon vs Canon...
Discussion in 'Photography Equipment & Products' started by DepthAfield, Aug 10, 2006.
  1. DepthAfield
    DepthAfield TPF Noob!
    Feb 24, 2006
    566
    Itchycoo Park
    In no way am I attempting to spawn a heated Nikon vs. Canon discussion with this thread, but I’m curious…
    Has anyone looked into reliability issues with either of these brands?
    A friend of mine, who is a die-hard Canon shooter, has had some of the worst luck with Canon film bodies. He has gone through two bodies in the past 8 months… The first camera had a film transport problem (only advancing film 2/3rd frame). His second Canon has developed a sticky shutter. I’m not sure of the models, but I do know they are not “entry level”, nor are they “pro”… Somewhere in between, “pro-sumer” I would guess.
    I’ve used Nikon bodies for years, both film and digital and have never experienced any trouble whatsoever. It makes me wonder if Canon has a quality issue.
    Thoughts?
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Sounds like bad luck to me...
    I have not seen anything to support that either company's cameras are more robust than the other. There are certain issued which have popped up over the years. Like Canon EOS 650, 620, 630 bodies with oily shutters...but that was back in the late 80s / early 90s and the have corrected the design flaw.
  3. Oldfireguy
    Oldfireguy TPF Noob!
    Jan 8, 2006
    987
    6
    Puyallup, WA
    I've used Nikons for over 35 years, film and digital. If I didn't have a ton of Nikon equipment I may have switched to Canon a few years back.
    I think one is as good as the other.
    I think your friend just had some bad luck.
  4. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    ditto to the above two. i've had a nikon that acted up a couple times, but i got it working again. those aren't common problems...if they were, nobody would buy the products. both camera companies make very reliable cameras if kept up correctly. even if something happens, you should have a warranty to help take care of it.
  5. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    Delavan, Wisconsin, USA
    Both are excellent and reliable systems. I had a Canon AE-1 for many years and did have it refurbished a couple of times but I did shoot thousands of rolls of film through it as well.
    I now have Nikon cameras FM2n and F5 mostly because I can use the same lenses on both bodies. You can't do that with Canon. The old FD lenses for the manual bodies won't work on the new AF/Digital bodies.
  6. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    Both companies occasionally have had issues. Both are rock-solid for the most part, however. Neither one is clearly superior to the other across the board, which is why they both have huge market shares.
