NikonD3000 and this lense?
Discussion in 'Photography Equipment & Products' started by ababysean, Apr 30, 2010.
  1. ababysean
    ababysean TPF Noob!
    Apr 29, 2010
    1,965
    103
    Pensacola, FL
  2. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    It will auto focus just not on your camera. You would need the one in your second link (It needs to say AF-S)
    The first one works on more expensive bodies that have the autofocus motor on the body, whereas yours needs the autofocus motor to be in the lens.
    I have the 35mm and it's a great lens.
  3. JustAnEngineer
    JustAnEngineer TPF Noob!
    Apr 11, 2008
    609
    Heart of Dixie
    The D3000 and D5000 cameras can only auto focus with lenses that have the focus motor built into the lens. Current Nikon lenses with built-in motors are labeled as "AF-S". A handful of older ones were labeled "AF-I". Tamron lenses with built in focus motors are labeled "BIM", while Sigma labels theirs "HSM".
    If you want to auto-focus with the "AF" lenses that have a screw drive, you need a D90 or better Nikon camera with the focus motor and drive in the camera body.
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    It is hard to say which is better. It depends on what you are going after. If you compare a lens based on AF, yes the AF-S 35mm lens is better since the lens can AF with your camera. However, since the focal length of these 2 lenses are different, therefore comparing them become meaningless.
    For example, a manual transmission full size truck is better or a small 4 doors Prius with automatic transmission is better?
    If you find that you need to use a 50mm f/1.8 lens, you will then need to get the 50mm lens.
  5. JustAnEngineer
    Apr 11, 2008
    609
    Heart of Dixie
    If you want to use a 50mm lens on the D3000, you have other options that can auto-focus with the low-end Nikon DSLRs, like the $440 Nikon AF-S 50mm f/1.4G or the $500 Sigma 50mm f/1.4 HSM.
