Nikon's CLS Problem
Discussion in 'Photography Beginners' Forum' started by BoxPhotographer, Jan 1, 2010.
  1. BoxPhotographer
    BoxPhotographer TPF Noob!
    Jun 23, 2009
    101
    Ontario, Canada
    I'm trying to use my SB-600 wirelessly but the pop up flash still fires. In the menu I have something like
    "Pop up flash: - -" which I though it would have meant that the pop up flash would be off and wouldn't fire.
    How do I fix this problem?
  2. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    Pop-up flash supposed to fire - it sends out a signal as a MASTER to your SB600, a slave, to fire. It doesn't contribute to exposure though.
  3. Captain IK
    Captain IK TPF Noob!
    Dec 5, 2008
    630
    Windsor, ON. Canada
    On the D90 there is a setting under the flash menu to adjust the pop up flash.
    IgsEMT is right. The pop up does control the slave so it needs to fire, but you should be able to control whether or not you want it to contribute to the exposure or not.
    I use the CLS system all the time with 2 off camera SB-600's. It works very well.
  4. Shockey
    Shockey TPF Noob!
    Dec 3, 2009
    350
    Boise Idaho
    Commander mode.
  5. JAFO28
    JAFO28 TPF Noob!
    Dec 26, 2009
    353
    4
    NJ
    Hi, try taking a picture with the pop up flash when you have it in commander mode. On the d90 under the commander mode menu you set the built in flash to --. When you take the pic you will see it doesn't contribute to exposure like IgsEMT and Capt. said.
d80 cls not working
nikon cls not firing
nikon cls problems
nikon d80 cls not triggering
nikon d80 cls not working
nikon d80 problems firing
problems nikon cls
