No more E6 processing in town
Discussion in 'Film Discussion and Q & A' started by dinodan, Mar 4, 2009.
  1. dinodan
    dinodan TPF Noob!
    Jan 21, 2007
    417
    Charleston, South Carolina, USA
    Yesterday, I went to the photo place where I had been buying film and taking it to be processed for 20 years. Gone! (As in shut down.)
    For a while, they had been doing E6 in house, but then went back to sending it out.
    I then went to another lab in the area, but they don't do E6. They suggested Ritz camera at the mall.
    Rather than take it there, I'm going to try E Six Lab of Atlanta. Has anybody used them?
    This has got me wondering how long E6 will be viable...
  2. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,039
    80
    Kankakee, IL
    This happened to me several years back. I called Kodak asking for the names of Q Labs in the Chicago area... there were none!
    I'm at home, using an ancient G3 with dial-up, so I'm not able to find any links for you just now. But if you Google "Kodak pro" and follow the links, I believe they have a Q Lab locater. You should be able to find something closer to you.
    Good luck!
    -Pete
  3. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,869
    457
    L.A.
  4. Christie Photo
    Jan 7, 2005
    7,039
    80
    Kankakee, IL
    I'm at work now. Yes... E-Six is a Kodak Q-LAB. Seems they're the closest to you.
  5. dinodan
    dinodan TPF Noob!
    Jan 21, 2007
    417
    Thanks guys. I'll probably try the Atlanta place first as they're relatively close.
    D.
  6. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,224
    252
    Los Angeles
  7. randerson07
    randerson07 TPF Noob!
    Apr 4, 2008
    279
    Pingree Grove, Illinois
  8. Christie Photo
    Jan 7, 2005
    7,039
    80
    Kankakee, IL
    Thanks for the link.
    -Pete
  9. bhop
    Dec 10, 2007
    2,224
    252
    Los Angeles
    I haven't tried the E6, but I have used the same package size C41 and it's supposed to be good for around 8 rolls or so..(of 120, probably a few more 35mm) but I only mixed half of it because I use a stainless steel tank, if I mixed it all at once, it'd be a huge waste, so that should double it unless I screw something up.
  10. North Light
    North Light TPF Noob!
    Jun 12, 2009
    Chattanooga TN
  11. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    I've used this kit, it's stated capacity is 8 rolls per liter (4 per pint). You could probably push it past that, but I haven't tried.
    I was scared to process color until I tried it, but it's actually easier to achieve consistent results then black and white. The only tricky parts are:
    1) maintaining the temp, I use a styrofoam cooler to keep the temps more stable.
    2) processing more film at a time; the chemicals are more expensive then black and white so you'll likely want to use them to exhaustion, and I wouldn't trust the dillutions lasting more then a couple days.
  12. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    JW Photo Labs in Raleigh is fabulous and they're somewhat in the general vicinity.
arista rapid e6 slide developing kit 1 pint
e 6 lab atlanta
e-6 processing los angeles
e6 film processing atlanta
e6 lab atlanta
e6 processing
e6 processing chicago
e6 processing los angeles
e6 processing seattle
ektachrome processing los angeles
