No success with IR filter
Discussion in 'Digital Discussion & Q&A' started by JSmith, Dec 25, 2008.
  1. JSmith
    JSmith TPF Noob!
    Sep 27, 2008
    11
    Hello, I received a 55mm Hoya R72 Infrared Filter for my Sony A300 DSLR today as a Christmas present.
    I've been trying it out but have had little success.
    When I try and take a photo indoors or outdoors I get nothing but blackness.
    The only time I can see anything is when I have put it on 30sec exposure and pointed it directly at the sun or a filament bulb.
    Can anyone help me?!
    Regards,
    JSmith
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I doubt you'll get much of anything indoors...
    What's the weather like? If it's cloudy you're going to need much longer shutter times than a bright sunny day.
    It's a little different from camera to camera, but I get shutter speeds around 10 seconds with a 350D (in bright sun)
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    what was your ISO?
    You may need to boost that as well.
    And what has already been mentioned, a bright sunny day is needed to cut the exposure times.
  4. JSmith
    JSmith TPF Noob!
    Sep 27, 2008
    11
    There was a weak winter sun, quite a few clouds.
    ISO was 100 and shutter speed 30sec :(
    Yeah, indoors was rubbish.
    Outdoors I could just see the sky, sun and clouds :thumbdown:
  5. greyhoundman
    greyhoundman TPF Noob!
    Oct 24, 2008
    58
    I use one on my DS. I start with iso 400 and a 80mm lens.
    Some cameras have too good of an IR filter in front of the CCD cell. It can make using an IR filter almost impossible.
  6. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    You have to use a much longer exposure when using an IR filter on digital, unless you have your camera modified.
  7. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Wait for a nice sunny day, with lot's of sun. You really need direct sunlight for IR.
  8. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    Like O|||||||O said, you really need sunlight, since thats a good source of IR. It wont work indoors, since you wont have any IRlight (or not nearly enough) So you're gonna have to wait for a nice sunny day, without wind if its possible. Cause due to the longer exposures the trees and whatever can be moved by wind, making it all blurry. You dont really have to crank up the ISO, cause that only will lead to noise. I had some great results with a 350D, F5.6, 4 seconds, ISO100.
  9. greyhoundman
    Oct 24, 2008
    58
    Here is a sample of IR with the DS.
    1/15 sec, f4.5, 50mm, iso 400
    [​IMG]
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yes and the counter example is this one:
    12 seconds f/5.6 ISO200. Taken with the D200. The exposures on some cameras need to be very long, but taking the photo is possible on every DSLR released to date.
    [​IMG]
  11. bikefreax
    bikefreax TPF Noob!
    Jan 6, 2008
    379
    Columbia, MO
    WOW Garbz, that is great. Here is the best I have done on my Olympus e-510. O love your bright white trees.
    [​IMG]
