Noise in black and white
Discussion in 'Photography Beginners' Forum' started by Fox Paw, Jun 21, 2008.
  1. Fox Paw
    Fox Paw TPF Noob!
    Jun 3, 2008
    670
    Arizona
    When I convert an outdoor shot to black and white using channel mixer, I often get a lot of noise in the sky. This seems to happen most with early morning or dusk shots. It's there before I start tweaking the channels. Am I doing something wrong?
  2. elemental
    elemental TPF Noob!
    Feb 6, 2008
    646
    Are you shooting RAW or jpeg?
    It seems that I have this problem when I try to "push" one channel too far- minor adjustments are okay, but past a certain threshold quality starts to degrade rapidly. I found it seemed better in RAW.
    Don't forget that what is undesirable "noise" in color can turn to desirable "grain" in black and white. I sometimes shoot higher ISO than I would ever use for color (past 800 is completely unusable on my camera) when I'm planning on final output in black and white because I know it can be a pleasing effect.
  3. Fox Paw
    Fox Paw TPF Noob!
    Jun 3, 2008
    670
    Arizona
    Thanks for the response. I'm shooting in RAW now, but I had the same issue when I was shooting in jpeg. I know what you mean about pushing the channels too far but I get this at standard levels. Not a huge issue...maybe it's unavoidable.
  4. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    Post an example: color and b&w.
  5. Fox Paw
    Fox Paw TPF Noob!
    Jun 3, 2008
    670
    Arizona
    It shows up here, although it's less apparent after Photobucket compresses the image.
    [​IMG]
    [​IMG]
  6. djrichie28
    djrichie28 TPF Noob!
    Jan 24, 2008
    264
    7
    Waterloo, ON
    I don't have a solution to the problem, but can shed some insight to the noise removal. The noise removal filter works well on skys since you can use maximum strenght and not preserve the details since sky has very little detail from sharp edges anyways.
eliminating noise in color photos through channel mixer
how to clear noise in black & white photos
how to remove grain in black white photo
removing grain b&w photography
removing noise from black and white photos
