Noise?
Discussion in 'Photography Beginners' Forum' started by Adorkable, Jun 7, 2008.
  1. Adorkable
    Adorkable TPF Noob!
    Jun 7, 2008
    4
    So, I have a little bit of issues with my photography, one of those major issues is noise.
    Ugh!
    What's the best way to fix all of that?
  2. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    1. Set the exposure properly.
    2. Use as low an ISO as is possible.
    3. Shoot with a dSLR (larger sensors mean larger pixels which, in turn, mean less noise).
  3. Overkill-F1
    Overkill-F1 TPF Noob!
    Jan 13, 2008
    53
    What camera? My Canon S5is had a problem with noise if I used a high ISO. It had no problem if I stayed at ISO 100 or 200. There is software that can help with noise in post-processing. (noise-ninja sp?).
    ...Terry
  4. Adorkable
    Adorkable TPF Noob!
    Jun 7, 2008
    4
    I use a Canon rebel xt.
    And really? Because yesterday for example I didn't have the option to use a lower ISO due to the dimmed lighting we were going to be working with, so that noise software I might actually dig myself into.
  5. Dubious Drewski
    Dubious Drewski TPF Noob!
    Jan 18, 2008
    909
    4
    Lethbridge, Alberta, Canada
    You are a strange one. Why do you "talk" that way?
  6. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
    dont type so small, I cant see it properly :)
    Post an example of your pics with noise probs, also what were you shooting, could you have used flash or extra lights?
  7. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Noise Ninja is one of the better programs.
  8. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    If you have poor lighting, you need either a fast lens, a flash, or both. I shot a birthday party tonight and never broke past iso400 with my f/2.8 zoom and SB-600 flash for Nikon.
  9. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Hey Mav, just curious... what made you use ISO 400 with a flash?
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Balance. Just because you have a flash doesn't mean you wouldn't want some mood lighting in the shot too. I've often gone up ISO1000 while still using a flash only because I wanted the flash effect to be subtle compared to the background.
    That said. There are many cases I'd rather a noisy image than one taken by flash. Stage lighting is exactly one of those. Noise Ninja does a wonderful job, and if you actually print your images you will find that even at your max ISO you get very very good photographs. Obviously they're not going to look good blown up on A3 or zoomed in on your screen, but still more than usable.
