Not sure if this is the right place...
Discussion in 'Graphics Programs and Photo Gallery' started by Frequent Traveler, Dec 29, 2008.
  1. Frequent Traveler
    Frequent Traveler TPF Noob!
    Jun 1, 2005
    154
    for a question about configuring a new PC based graphics/video editing computer that will handle some heavy multi-tasking and NOT be maxed out... OK, so here goes!
    My *proposed* particulars;
    Power Supply: 680 watt SLI/CrossFire ready
    Processor: Intel Core i7-940 2.93 GHz 8M L3 cache LGA 1366
    Motherboard: Asus P6T Deluxe Intel X58 Chipset SLI/CrossFireX SAS
    Triple-Channel DDR3/1600 SATA
    Memory: 6GB (2GBx3) DDR3/1600MHz
    Video Card: ATI Radeon HD 4870 PCI-E 16X 512MB
    HD1: 1TB SATA-II 3.0Gb/s 32MB Cache 7200RPM
    HD2: 1TB SATA-II 3.0Gb/s 32MB Cache 7200RPM
    Optical Drive1: 20X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER
    Optical Drive2: 16X DVD ROM
    OS: Vista Home Premium 64-bit SP1 version
    Does this proposal raise any compatibility flags or performance deficit areas?
    TIA!!!!
    frank
  2. TGaston
    TGaston TPF Noob!
    Aug 13, 2008
    25
    Mobile,AL
    sounds like a good build, you wont need any overclocking, but six gigs of ram sounds like a bit of overkill, what all are you planning on multing with?
  3. Frequent Traveler
    Jun 1, 2005
    154
    While i'm crunching video and/or large-ish photo files, i also need to be able to run financial software plus upload/download info from the web.
    Vista really drains the RAM so thats why i'm looking at a minimum of 6gb and thinking of adding 6gb more for a total of 12gb.
    I'm concerned about the 64-bit OS and what additional resources it may require to operate quickly and efficiently.
  4. SrBiscuit
    SrBiscuit TPF Noob!
    Apr 22, 2008
    2,721
    44
    NH
    personally, i would avoid the ATI card and go GeForce...my last experience with ATI was not a pleasant one, and in discussions with peers as to which direction to go with my video card 100% of them said to move on from ATI to GeForce.
    i like your idea of 6gb of ram....ram is cheap and can really boost performance.
    looks like you'll have a good amount of HD space...with such heavy lifting the HDs will likely do, maybe consider a RAID...just in case...they can be done for fairly cheaply these days...or are you planning on mirroring the 2 TBs you'll have?
  5. Frequent Traveler
    Jun 1, 2005
    154
    Yea, mirroring, yup thats what i'll do?!? ;)
    I don't know the first thing about configuring 2 HDD's - at all. I've read a little here and there about RAID set-ups as excellent storage/back-up systems, but don't know how to accomplish it all. I've been advised that 2 HDD's are a minimum and a 3rd may well be better for OS and programs - i dunno...
    Also, i'll look into the GeForce video cards - which NVIDIA is a better solution than the ATI Radeon card i've selected? Again, advice given to me mentioned that Adobe may work better with NVIDIA - but i work with GIMP! In the case i'll use, i can have up to 3 video cards so there should be space available.
    Thanks a ton!
    frank
