Objects slightly angled toward center of photo...
Discussion in 'Photography Beginners' Forum' started by dcb83, Aug 11, 2010.
  1. dcb83
    dcb83 TPF Noob!
    Aug 5, 2010
    11
    I've seen many pictures that have trees or buildings slightly tilted like at 80-85 degree angle toward the center of the photo. Objects on the right are slightly tilted to the left and objects on the left to the right. A fish eye lens wasn't used. I'de love to know how it's done.
  2. dcb83
    dcb83 TPF Noob!
    Aug 5, 2010
    11
    I kinda got somewhere with the lens correction tool in ps playing around with the vertical perspective. I lose a little of the photo on top though...
    Any thoughts...
  3. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    Its called converging verticals and happens when you aim a lens upwards at a point higher than your position on a building or taller object, this is why its better to get up to the level of the object to shoot it, you can as you know correct in software pretty well. H
  4. Slaphead
    Slaphead TPF Noob!
    Apr 28, 2008
    399
    Z├╝rich, Switzerland
    Exactly as flash harry has said, but you really need to use quite a wide angle lens to get the effect
    The example here was shot at 10mm.
    As the focal length increases the effect diminishes - at around 50mm you won't really see the effect at all
  5. dcb83
    dcb83 TPF Noob!
    Aug 5, 2010
    11
    Cool. I really like this effect.
  6. Flash Harry
    Jun 26, 2006
    1,966
    14
    Durham, UK
    No, it happens with any lens to a certain degree, try it, the one you posted does not suffer converging verticals its simply because you used the WA in portrait mode, not a good idea unless you tend to do a central crop. I say again, converging verticals is caused by tilting the lens upwards, usually to include a tall object in the frame, this is one reason for a T/S lens or T/S panel in large format as correction with film in the darkroom is a pain in the butt, so, you get it right in camera. H
