Off camera lighting for outdoor portraiture - will this work?
Discussion in 'Photography Beginners' Forum' started by dMau1986, Sep 13, 2010.
  1. dMau1986
    dMau1986 TPF Noob!
    May 5, 2010
    16
    St.Paul/Madison
    I am looking to play around with some off camera lighting for (mostly outdoor) portraiture. I am not looking for anything crazy (read: expensive). Would the following be sufficient, or am I in completely wrong direction?
    I am looking at an entry-level Metz speed light flash and I would pair it up with a wireless trigger.
    Would this work for outdoor portraiture and perhaps single light source indoor portraiture?
    Metz mecablitz 36AF-4C AF E-TTL Flash for Canon EOS MZ 36341 -
    [​IMG]
  2. Derrel
    Derrel Mr. Rain Cloud
    Top Poster Of Month
    Jul 23, 2009
    36,795
    13,492
    USA
    Looks like it would work....and it's under $100 in price.
  3. dMau1986
    dMau1986 TPF Noob!
    May 5, 2010
    16
    St.Paul/Madison
    A couple concerns I have:
    -Would this be powerful enough?
    -Would I need some sort of softbox/reflector (by itself would it be too harsh?)
    -I heard mention that you can only control the power through the camera's settings. So if I use a wireless transmitter, does this mean I am then unable to adjust the output? Can anyone verify/explain this too me?
  4. KmH
    Apr 9, 2009
    38,745
    5,160
    Iowa
    It will depend which wireless triggers you get.
    In general, both the camera and the speedlight will need to be in manual mode for OCF.
    You don't mention what camera model.
    Any light modiifiers will eat some of the light it puts out, but the light will be softer, and I didn't think it had very much power at a GN rating of only - Guide No. 98'/30 m at 50mm. GN numbers are generally tagged to ISO (ISO 100) not focal length.
  5. dMau1986
    dMau1986 TPF Noob!
    May 5, 2010
    16
    St.Paul/Madison
    I realize it won't be anything fantastic, given its very inexpensive cost. I am simply looking for something to play around with and enhance portraiture a bit. Do you think this would get me by for a while?
    Body is a 40D.
    Can anyone check the link/specs on the this model to help verify if the output is manually adjustable when using off camera? I am not sure what I would be looking for.
  6. KmH
    Apr 9, 2009
    38,745
    5,160
    Iowa
    From the B&H link you provided, click on "Specifications" :
    Type Shoe mount Guide No. 98' (30 m) at 50mm
    118' (36 m) at 85mm
    Angle of Coverage 75 to 28° (28-85mm in 35mm format)
    Auto f/Stops No, full TTL at all apertures
    Manual Power Setting No
    TTL Dedication Yes,
    E-TTL II Bounce Head Yes
    Swivel Head No Zoom Head 28-85mm (manually adjusted)
    Off Camera Terminal No
    Recycle Time 5 Seconds (based on fresh batteries & full power)
    5 Seconds with alkalines
    No Lithium Batteries Power Source Four 1.5-Volt "AA" batteries (alkaline, NiMh & NiCd)
    (Lithium Batteries Cannot Be Used) Dimensions 2.8 x 4.3 x 3.4" (73 x 110 x 87mm) WxHxD Weight 7.2 oz (205 g)
  7. dMau1986
    dMau1986 TPF Noob!
    May 5, 2010
    16
    St.Paul/Madison
    Oops, thanks :blushing: I had been looking at the manufacturers site and could not locate that detail.
    Would this be an issue for using this flash for off camera lighting then?
  8. Flash Harry
    Flash Harry TPF Noob!
    Jun 26, 2006
    1,918
    Durham, UK
    It'll be at full power off camera, so adjustable by aperture, distance or diffusion, take your pick, Metz have been top level Flash producers forever. H
  9. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    It's still doable, it would just be less versatile.
    To control the exposure from the flash, you can adjust the aperture, the ISO, the flash power or the distance from flash to subject. So if the flash doesn't have manual control, and always fires at one power level (full), you can still adjust the exposure with those other variables.
    One issue is that with full power flashes, your recycle times will be slower and you'll use up batteries faster than if you could use a lower power setting.
    You may also have trouble using larger apertures, if you wanted a shallow DOF for example.
    Have a look at THIS flash. It was designed for off-camera type work.
  10. ghache
    ghache No longer a newbie, moving up!
    Jan 25, 2010
    3,570
    295
    If there is no manual power control then id say get something else,
    i am using vivitars 285hv and they work really good outdoor for fill flash,
    they are about 100$ Vivitar 285HV Flash 233965 - B&H Photo Video
    with a gn of 120, its enought power for fill light using a umbrella or a small softbox, or even overpower the sun around 6-9pm (i did it a couple times but with 2 unit)
  11. ghache
    Jan 25, 2010
    3,570
    295
  12. anel
    anel TPF Noob!
    Mar 5, 2009
    172
    i'd suggest either a vivitar (they're great but i only have one because of the crazy shipment costs) or a yongnuo flash (i have it and it's awesome) and of course cheap, full automatic controls and costs like 70$
    and i don't agree that these flashes are "something to fool around until you get something better", i actually think these flashes will be of use for a long time, at least for me, they're awesome, cheap, reliable and pretty strong.
camera settings for outdoor portraits
lighting for outdoor portraits
metz speedlight
off camera lighting
off camera lighting outdoors
off camera outdoor lighting
outdoor off camera flash
outdoor off camera lighting
outdoor portrait lighting
outdoor portraiture
