Robin Usagani
- Joined
- Jun 6, 2010
- Messages
- 10,347
- Reaction score
- 2,174
- Location
- Denver, CO
- Can others edit my Photos
- Photos OK to edit
I also suggested going to custom function and lock the flash to 1/200-1/60 on the aperture mode.
If you set it to TV, the camera will always choose f/2.8 if you are using the 24-70mm in that light condition right?
Forget about using manual especially if you are still really new with flash. I would use TV mode and set it to 1/60 shutter speed. Set the ISO to 400. Use your flash on E-TTL mode if you have external flash. If you dont , then use your built in flash. Use the 1/60 shutter speed only when your subject arent really moving (standing at the altar). If they start to move around, change it to 1/200.
By doing that, you only have to worry about 1 thing, shutter speed. Dont use the P mode, your shutterspeed will be too slow at most scenarios.
If it's in TV, the aperture is going to fluctuate. Better to set it for manual and be able to adjust what you need to on the fly and let your flash do the rest of the work.
