Ok...am I nuts?
Discussion in 'Digital Discussion & Q&A' started by wildmaven, Nov 20, 2007.
  1. wildmaven
    wildmaven TPF Noob!
    Aug 3, 2007
    985
    Picking up dog poops
    When I bring up a photo and it needs to be rotated 90 degrees clockwise, and it's a picture of someone's face, for some reason they look thinner when I rotate it than they did before I did it. What gives? Is it an optical illusion or is something happening to the file? :er:
  2. Bevel Heaven
    Bevel Heaven TPF Noob!
    Aug 28, 2007
    237
    Pleasant Hill, CALIFORNIA
    it's an optical delusion............
    Do the same for any photo.......... see how it looks?
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    it is an optical illusion. everything looks different when view from a rotated viewpoint.
    many master printers print negatives upside down as then they pay attention to the compostion of light and shadow rather than a specific image.
  4. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Ya, it's just your screen might be stretching it or something when it's sideways...I dono...
    But it usually does look a bit different if it's not right way up.
    I have my camera do all the flipping...
  5. Joxby
    Joxby TPF Noob!
    Sep 5, 2007
    272
    7
    Yorkshire
    Is your moniter wide screen ?
    I bought a wide screen, I thought it would be easier to see the million edit windows I have open without any of them overlapping the image.
    All it does is stretch everything, so its exactly the same as before I got a wide screen for cluttered windows.
    Theres probably a work round, but I cant be bothered.
  6. wildmaven
    wildmaven TPF Noob!
    Aug 3, 2007
    985
    If that were the problem, I'd think it'd be the reverse of my problem, that it would make the face look thinner before I flipped it, because it was stretching it. Hmmmm...
  7. Joxby
    Joxby TPF Noob!
    Sep 5, 2007
    272
    7
    Yorkshire
    Yes, mine actually look correct sideways, then put on 20 stone in portrait:lmao:
  8. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
    Pixels are usually taller than they are wide so if something is 800 pixels on it's side it will be compressed slightly and appear to stretch out when it's vertical.
    I'm amazed Sideburns didn't call you stupid for not knowing this. Just amazed since I don't know what FAST RAM is.
  9. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    You will usually have some display options that change the aspect ratio of your monitor. Make or get an image of a circle and then set your monitor aspect ratio and the screen vertical and horizontal compression until you see a perfectly round image on the monitor.
