OK, really stupid question.....
Discussion in 'Photography Beginners' Forum' started by kidchill, Apr 26, 2008.
  1. kidchill
    kidchill TPF Noob!
    Jan 27, 2008
    249
    Brooksville, FL
    I finally got a 1.4 lens that actually has an aperture ring. When I put that on the body, do I need to fully open it? I think I read that somewhere, but I'm not totally sure....I know, I know...It's a stupid question, but I've never used a lens with the ring....
  2. RKW3
    RKW3 TPF Noob!
    Apr 30, 2007
    1,716
    So Cal
    I'm not sure, so I tried my best at googling some info.
    Does this quote answer your question?
  3. kidchill
    kidchill TPF Noob!
    Jan 27, 2008
    249
    Brooksville, FL
    Kinda helps...I read that in the manual...But I thought I read somewhere that you have to completely open or close the aperture when you actually physically attach it to the body...I just don't wanna jack-up my new lens!! ;)
  4. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    It depends on your camera and what exposure mode you're in. If it's P or S mode, set it at it's smallest aperture. If it's A or M mode, set it at the aperture you want to shoot at.
  5. kidchill
    kidchill TPF Noob!
    Jan 27, 2008
    249
    Brooksville, FL
    Okay...it isn't about controlling the aperture. When I physically attach the lens to the camera body, does the aperture need to be wide open?
  6. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I know with any Nikon DSLR any lens with an aperture ring is to be set on the smalest aperture at all times. The body has knobs that are used to control the aperture in A or M. I would assume this is the case with Canon as well but I cannot be sure.
  7. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    I'm not sure what you're asking. When you attach the lens, the camera opens it for viewing and focusing no matter where you set the aperture ring.
  8. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    If it's an AF or AF-D lens, you'll need to set the aperture to minimum (f/16 probably on an f/1.4), otherwise you'll get an error. Then use the aperture lock so that it doesn't slip off. If it's an older AI or AI-S lens then it'll only meter on your D300 and you'll need to manually open and close the aperture.
  9. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    No, your aperture does not need to be wide open unless your camera has no depth of field preview. That would be the only reason for opening the aperture first. On modern lenses (anything less than 40 years old) you twist or thread the lens onto the camera body and, even with the aperture stopped all the way down, this mounting motion precludes the need to open the lens up before mounting it to the camera body. So, in short, NO.
  10. ToddB
    ToddB TPF Noob!
    Oct 20, 2007
    182
    Raleigh, NC
    jerk mode on
    RTFM I'm sure it tells you what to do in there.
    jerk mode off
  11. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Yeah that is jerk mode because in the many years I worked at RItz this was problem came up on a weekly basis. If you have ever read a Nikon manual you will see they are pretty complicated for most people to comprehend and what may seem simple to you can totally perplex even the most tech savvy person whomay have over looked such a simple thing. I think turning on your camera and seeing F EE flashing and not knowing what to do can be very frustrating and make anyone start pulling their hair out and instantly assuming they are oing to have some kind of huge repair bill.
  12. kidchill
    kidchill TPF Noob!
    Jan 27, 2008
    249
    Brooksville, FL
    Actually I did read the manual...In english, japanese, german, french....and whatever that weird other writing was. It just said to leave it in f/16 for A/S/P mode...I just thought I had read somewhere that to physically attach the lens (not to use it in any special way) that the aperture needed to be all the way open. That's all. My question wasn't about shooting at all. Literally, it was just attaching the lens.
