Old Barn in the White Mountains
Discussion in 'The Black & White Gallery' started by Big, Jun 21, 2010.
  1. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    [​IMG]
  2. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    Nice procesing, I really like
    I'm not sure about that piece of fence at the bottom of the frame and then leads to the house, kind of cuts from the simple image of the house.
  3. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Thanks! I played a lot with the b&w trying to get something I really liked. I could shoot old barns all day long. Just something about them I love.
  4. white
    white TPF Noob!
    Mar 7, 2010
    1,131
    7
    Perhaps it should be titled Gray Barn in the Gray Mountains?
    Too much gray. For me, it doesn't work as a black & white image because the scene (and the way it's shot) does not emphasize the strengths of b&w imagery. There's no texture or contrast, which is like Rule no. 1 when it comes to b&w.
    Green and blue are both reduced to middle gray. The same is true for red. Was the barn red? I will slice my wrists to the consistency of cured ham if you shot a scene with red, green, & blue as black and white. What a waste of color!
    But the barn is probably a boring, country brown. I still think that would be better than what you have here. The picture needs contrast -- color contrast, or more b&w contrast.
    I like the diagonal fence line leading from the right side. I don't like the nearly vertical fence line going toward the house. Right idea, bad execution. Get a better angle on the fence, like moving to the left or right more. Turn both lines into diagonals.
  5. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    ^^^ I think I give up on b&w's. If I boosted the contrast, I would lose the detail in the barn walls. Also the primary colors of this scene were red, green, and blue...
  6. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    I hope you dont mind my editing this.
    What I done:
    first - Correct the levels, press auto worked fine.
    if you want to be really specific when lightening an image and dont want to mess with colour detail and stuff, change image mode to LAB and lighten the lightness channel (default when levels is open)
    second - I pushed contrast to +100
    third - I used curves to brighten the sky to seperate it from the image to give more depth
    fourth - applied image and sharpened
    (using unsharp mask: amount: 205% radius: 0.8 threshhold: 0.)
    fith - I used gaussian blur to reduce the sharpness a bit, (0.3 strength.)
    [​IMG]
    obvious banding is noticeable, due to the fact I was using a compressed image, using raw wouldn't be so noticable.
  7. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    Personally, I like the dark sky in the original. The only thing I would do is lighten it up just a hair while holding the sky if possible, and while not increasing contrast.
    To each his own! Capisce?
    Big, don't give it up. It looks pretty good as is.
  8. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Well, I was going for the look of b&w because it's an old barn and when I think old photos, I think of black and whites... I like the edit William but the top left is a little distracting. Thanks for commenting guys!
  9. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    you could always push the curves to make the top left brighter too.
    original was nice, just felt flat as it didn't have much speration and was more grey than black and white.
  10. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Here's an edit I just did. I dodged the sky and the side of the barn and also burned the fence posts a little and the mountain too. I like it a lot I think. Now looking at the original, it does look "blah". I'm just glad people think it's worth taking their own time to edit it for me!
    [​IMG]
  11. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Our edit is much nicer now, you are getting a little bit of halo around the barn door, just be careful when using a soft brush.
    much better contrast now.
  12. Big
    Big TPF Noob!
    Apr 22, 2009
    1,228
    New Hampshire
    Ya I just fixed that on the saved version on my computer. It was just a slip with my burn tool, I didn't hit that one spot. You got good eyes! :lol:
photos new hampshire white mountains barns
