Old film carmera lens
Discussion in 'Photography Beginners' Forum' started by akazoly, Jan 15, 2008.
  1. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I have an older SLR film camera.
    [​IMG]
    Is possible for me to use this lens on Nikon D40X in manual focus ? I need a converter?
  2. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    That lens is an 'M42' mount...so it can't be directly mounted onto your Nikon camera. You can get an adaptor (See Here for an example).
    However, the adaptor moves the lens farther away from the camera, so you can't focus to infinity. You would also have to set the aperture manually.
    You may be able to find an adaptor that has a lens element, and would be able to focus to infinity...but the quality of the lens element is usually pretty crappy.
    So unless you have a great lens, it's usually not worth the hassle (unless of course, you just want to play around with it).
  3. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    The lens has a pin (marked with red):
    [​IMG][​IMG]
    This pin not scratch the CCD ?
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    I'm not sure the purpose of the pin...I don't have any cameras with M42 lenses. It might be a locking pin or something like that.
    Have you looked into your camera with the lens off? The sensor is way down in there. If anything, the mirror might cause an clearance problem...but probably not.
  5. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    The CCD is like 2 inches from the mount.
  6. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    The purpose of the pin is to stop down the lens at the time shutter is tripped. You should see the aperture blades close when you push the pin in.
  7. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Yes is true, the pin is useful in auto mode.
