Old flash on Nikon D40X
Discussion in 'Photography Beginners' Forum' started by akazoly, Jan 19, 2008.
  1. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
  2. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    The flash work pretty good, but I want to know damage the camera ?
  3. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    This question comes up fairly often. Do a search on the forum, somewhere in a thread there is a link to a list of "safe" and "unsafe" flashes.
  4. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Thanks! I take some photo with older flash and Nikon D40X one hour ago. Now I scare, I don't want to use the old flash again. What you think, my camera is damaged?
    Hmmm... I don't notice any problem with camera..
  5. shorty6049
    shorty6049 TPF Noob!
    Mar 8, 2007
    1,906
    Minnesota
    then its not damaged... you'll know if it is
  6. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    What is the symptom for damage, you has any idea? I take 10-15 photos with two older flash. Now I don't take more photos with older flashes...
    Thanks!
  7. shorty6049
    Mar 8, 2007
    1,906
    Minnesota
    umm... i would think the camera wouldnt work. from what i know, if you use the wrong flash , it could fry your circuitry so it would just mess the whole camera up
  8. Noob7_0
    Noob7_0 TPF Noob!
    Dec 23, 2007
    16
    Ontario, Canada
    I found out when I spoke with the people at my local shop that some flashes can cause a voltage serge to the camera. You may need to get a voltage sync to protect your camera. I think they are 70ish canadian
  9. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Some older flashes use a sync voltage as high as 250 volts and will damage the circuit in the camera that "pops" the flash. It usaly will not damage the whole camera, but I guess there are exceptions. Most modern cameras are designed for a sync or "trigger" voltage os around 6 volts or less. I don't know about your flash, but if you purchased it new in the last 10 years or less, it's a fair bet it's OK. No, another issue, the flash most likely not work in TTL mode and will only auto-expose in simple Auto mode. That is it won't get it's auto-exposure info "Through The Lens", but from a sensor on the front of the flash. It works, but not a accurate as TTL.. Good Luck.
  10. Happy Hour
    Happy Hour TPF Noob!
    Dec 5, 2007
    453
    Chicago IL
    This came up with my camera i have a sony and was told only 2 of Minolta's flashes will work on my camera and don't try using the other ones they will blow your camera! well I have 3 non recommended flashes That sony says will not and cannot work on their camera! But all 3 do Just fine also and i've shot thousands of pics with them on my cam so far! I personally think it's a scam for you 2 spend more money!!! but that could only be true to Sony and not your camera! but i say if it works it won't hurt your cam at all.IMO
  11. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Thanks, I think my camera work like a charm. The built-in flash pops out. The camera take photos. ;)
achiever 321az
achiever 321az flash
achiever 321az flash volts
achiever321az
flash circuit for nikon
nikon d40 flash trigger voltage
nikon d40 flash voltage
nikon flash circuit
nikon old flash
old nikon flashes
