Old flash won't work on new camera, any ideas?
Discussion in 'Beyond the Basics' started by Oso, Jan 30, 2010.
  1. Oso
    Oso TPF Noob!
    Jan 15, 2010
    Outskirts of Dallas, TX
    Hello all,
    I have read this forum for a while, then registered so I could join in. There is a lot of good advise and good people here.
    I have an issue I am hoping someone here can assist me with.
    I had a Minolta 7000 camera, lenses and flash.
    The camera was dropped and broke. I asked the photo store what cameras would use the lenses I currently own and was told Sony Alpha. I bought a Sony a100 (been a while since I used it due to motorcycle wreck and being laid up).
    Now, I am starting to play with it again and went to put the flash on and practice some flash images. I ran into an issue at this point.
    The flash I have is a Quantaray QBX-8000xi. It would not fire off camera. I searched the web and find out that it will not work with the Sony A100. Apparently, the only real solution is to buy a Sony flash. I will probably do that when I can get the cash together, they run $229 on ebay with free shipping.
    Now, my main question here is this; Can I use a radio trigger of some kind to make the Quantaray flash go off? If I could add a radio trigger and mount the flash on a tripod with a box on it, I could use it as mobile light source. Is this possible? I have no knowledge of radio stuff. I know I can get a Sony compatible radio that the camera can talk to but can I get the flash end and make it all talk?
    I just do not want to loose the flash I have if I don't have to. I could sell it on ebay and put that cash towards a Sony and will if that is the better option.
    You are the smart guys so I ask you, what should I do?
    FYI I have not worked since my motorcycle wreck (T-Boned by a Suburban, hit and run. In a wheelchair for over a year and still having trouble physically) and therefore cost is a MAJOR issue.
    Thanks to all.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Welcome to the forum.
    In theory, your plan should work and you should be able to use a radio trigger to fire the flash off-camera. My only concern would be the radio transmitter and how well it would work with the camera. I think that the Sony hot-shoe is a bit different than the standard that everyone else uses....so if you get a radio trigger, make sure that it's compatible with Sony cameras.
