I am looking for suggestions for some older wide angle prime lenses for my Nikon D5100. I would like to keep it under $100. Any suggestions? Manual focus and aperture is fine
That's the problem, the older lenses were for film, so 28mm was wide and popular as was the 35mm. They are what you can find cheap. A 24mm or 20mm is probably at least twice your budget. The 18mm on a kit lens on the D5100 is about like the field of view of the 28mm, so most the time it is better to just use a kit lens for something cheap on the wide end.
10-17mm lenses are a relatively new phenomenon. And as another poster stated, older 18-23mm lenses used to be specialist lenses and are fairly expensive. Wide angle for aps-c is one area where you can't really save much money by buying older lenses.
Your 18-55 kit lens is a good option, optically its probably better than some of the older glass out there.
For $100, take a look at the 100 2.8 Series E if you want to have some fun with older glass. But just be aware its fully manual and wont meter (I don't think) on your D5100.
