Old rangefinder
Discussion in 'Film Discussion and Q & A' started by Coldow91, Mar 22, 2008.
  1. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    I want to buy an old rangefinder (35mm) to use along side my Canon A-1. I don't want to spend much at all and was looking at the Fed 2 and Fed 5. Would these be good? and since they are not metering I could always use the sunny 16 rule or my canon to meter right? thanks for the responses and I am open to other suggestions
  2. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    I have a fed three I have used off and on for about five years. It always works for me just fine. I sure would hate to go out to do something important with it, but it has never let me down. Of course if it had I wouldn't still have it.
  3. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    Ok thanks! I will keep researching but I sounds like something I want
  4. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    Sorry double post
  5. Smith2688
    Smith2688 TPF Noob!
    Jun 18, 2005
    231
    The Island
    Something from the Yashica Electro line would be nice, but they're rather large. The Canon Canonet and any of the Olympus 35's would be good too.
  6. nealjpage
    nealjpage multi format master in a film geek package
    Sep 16, 2005
    3,479
    Oregon
    Charlie! Where you been?? Welcome back.
  7. doobs
    doobs TPF Noob!
    Oct 7, 2007
    566
    Sacramento, CA
    Canonet QL17
    Mine was 12 bucks and works amazing.
  8. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    where did you get yours?
    it seems to be what I am looking for
  9. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,994
    496
    L.A.
    The Canonet QL 17 is a great camera (I have one too and love it) but there
    are a couple of things you should know. The camera was designed for the
    mercury PX625/PX13 battery which are now discontinued. Most "replacement"
    batteries are not mercury and produce a higher voltage so meter accuracy
    may be off. But, there is a battery available that produces the correct voltage
    from Wein called the MRB625.
    The other thing to watch for is that nearly all of these cameras need the
    foam replaced around the film door because Canon used a type of foam
    that deteriorates into a black goo, which is how you usually find them now
    unless it's already been replaced. It's not difficult to replace the foam your-
    self.
    But, these cameras are worth the trouble. They are one of the best fixed
    lens rangefinder cameras ever made.
    You might also consider some other, similar cameras described here.
  10. Coldow91
    Coldow91 TPF Noob!
    Sep 14, 2007
    1,370
    USA
    ok thanks for the helpful info
  11. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
  12. AndrewG
    AndrewG TPF Noob!
    May 15, 2008
    155
    Exeter, UK
    I used a Fed4L when I was starting out; the main benefit-if it is imortant to you, of course-is the built-in meter. I seldom had badly exposed pictures with it. Do try and examine the camera rather than buying unseen as these are now rather elderly and quality control when new wasn't what it could be!
