Older Flash on new dSLR
Discussion in 'Beyond the Basics' started by robc638, Oct 18, 2008.
  1. robc638
    robc638 TPF Noob!
    Oct 18, 2008
    15
    Montreal, Quebec, Canada
    Some of the gear from my 35mm kit is still in useable condition. I am thinking of the old lenses and flash. According to my manual, older Nikon lenses will fit on the new camera bodies, although some features will not be available. However, the manual does not mention anything about using any other flash types except the Speedlight series.
    I have a Vivitar 283 flash and was wondering if there would be any danger by putting it on the hotshoe and firing it from the camera? The 283 is a non-dedicated flash, so I would have to set the camera in manual mode, setting the shutter and aperture manually to match the flash.
    The camera I use is a Nikon D60.
    Thanks.
  2. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    yea, you can use it, but you should use a slave like the Nikon SC-28 because if there is a wattage difference between the flash and the camera, you COULD fry your camera...
  3. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Do you mean the trigger voltage? And you may want to measure the trigger voltage of the flash with a multimeter and see if it is too high for your camera.
  4. Alleh Lindquist
    Alleh Lindquist TPF Noob!
    Oct 2, 2008
    244
    Portland OR
    Should have no issues at all.
  5. RacePhoto
    RacePhoto TPF Noob!
    Dec 29, 2006
    562
    5
    Wisconsin
    And now the real answer. Maybe? :er:
    Some older units have high voltage, some Chinese and Korean versions of the same flash, are just fine.
    Here's a link that may be helpful, but the answer is still maybe, depending on which place it was made and when.
    http://www.botzilla.com/photo/strobeVolts.html
    For anyone else, the link is not just for Vivitar it's a pretty big list of flash units and their trigger voltages.
    Oh yes, the flash will work as a manual flash and I use an old one to defeat the pre-flash on my Canon cameras, when I'm triggering old slaves. New flash, you need new slaves.
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Excellent. I lost that list when i accidentally deleted my firefox profile. Thanks RacePhoto :D
  7. robc638
    robc638 TPF Noob!
    Oct 18, 2008
    15
    I made a mistake, it is a 285HV. I checked the voltage as instructed on the website and it reads 8 Volts. I guess I won't be using this flash with my new D60. I'll save it and use it as a slave triggered with a photo sensor.
  8. DavidSR
    DavidSR TPF Noob!
    Oct 1, 2008
    262
    Rowlett, TX
    8 volts should still be acceptable for digital. I use my 285HV on my Canon XTi all the time and have had no issues, but if you're in doubt you can use this...
    [ame]http://www.amazon.com/Wein-SSHSHS-Safe-Sync-Shoe-W990560/dp/B00009UU18/ref=sr_1_1?ie=UTF8&s=electronics&qid=1224516398&sr=8-1[/ame]
  9. Mike_E
    Jan 26, 2007
    5,327
    266
    Nikon cameras are supposed to be good to 250V. Fire away!
  10. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,067
    87
    Kankakee, IL
  11. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    8v is fine for a modern dSLR. Most now can handle up to 250v.
  12. robc638
    robc638 TPF Noob!
    Oct 18, 2008
    15
    The website said 6V so I assumed 8V was too much.
    Can anyone confirm if Nikons can handle high voltages?
    Thanks.
