Olympus XA ISO settings
Discussion in 'Film Discussion and Q & A' started by essjayyell, Mar 13, 2007.
  1. essjayyell
    essjayyell TPF Noob!
    Nov 2, 2004
    216
    Newcastle, Australia
    I just purchased a nice little XA and noticed the ISO settings seem to go up from 25 to 800 in strange increments. It goes -
    25 . . 50 . . 100 . . 200 . . 400 . . 800
    Here is a photo to explain it better
    [​IMG]
    Can someone tell me what ISO value each dot in between the numbers would represent?
  2. Orrin
    Orrin No longer a newbie, moving up!
    Jul 6, 2006
    298
    53
    Sparks, Nevada
    Most films these days are 50, 100, 200, 400, etc. so you really don't need
    the in-between settings, but they are:
    25-32-40-50-64-80-100-125-160-200-250-320-400-500-640-800
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It's common for 'stops' to be measured in 1/2 or 1/3 increments. So you could think of it as ISO 200 + 1/3.
  4. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    If you're confident in the camera's meter and want to shoot at the film's standard rating then you could just set it to the labelled ISO, but otherwise you could presumably use the increments for exposure compensation.
  5. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    Great little camera, I have had one since they first came out.
  6. essjayyell
    Nov 2, 2004
    216
    Thanks a lot for the help :)
  7. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    "...otherwise you could presumably use the increments for exposure compensation."
    That is exactly how you use the steeings since the camera is strictly aperture priority. There is also the little tab on the bottom back of the camera that is used for a one and a half stop increment for backlit subjects.
    The pressure sensitive switch (the square red button on top) that activates the shutter tends to get dirty contacts. It's a simple enough matter to take the camera body apart and clean up that contact.
  8. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Thanks for clearing that up. I said 'presumably' because the later XA2/3 (compacts with zone focus and no manual exposure control) have DX coding which would override those settings and I thought that might be the case with some later XAs but apparently not.
    Btw it is simple enough to take the body apart... but less simple to find the little ball-bearing from the sliding cover once you drop it on the floor :oops:
  9. Patrice
    Dec 6, 2006
    2,392
    381
    I know what you mean, the second time I had to do it, I made sure it was over a big mixing bowl!
  10. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    Don't ever despair over losing the little ball-bearing, there are plenty to be found in pens like BIC. A little push with a needle is all you need and the little ball comes out. Washing it with alcohol makes it ready to go in place. ;)
olympus xa
olympus xa overriding dx
olympus xa setting iso
olympus xa2
